Modle Number: MRP-M350
All the info on the amp is on this site http://www.abt.com/product/12047.html.
Alpine V-Power Series Class-D Mono Amplifier, Model MRPM350
This ultra versatile Class-D amplifier offers both Speaker level and RCA inputs with a variable LP crossover, designed to work with any radio or in any system. The V-Power amplifiers enhance numerous system building designs with superb performance and value. It also has a Bass EQ for that extra kick and is Bass Engine® ready making it perfect for all Alpine head units.
Key Features:
14.4V RMS Continuous Power
2ohm; (0.3% THD) 350W x 1
S/N Ratio 90 dBA
24dB LP (50Hz) Crossover
Subsonic Filter
Bass Engine®
4 Volt Input Capability
STAR Topology
Darlington Bi-Polar Outputs
MOSFET Power Supply
Speaker Level Input
Blue Power Status LED
Features:
General
Bass EQ
Selectable Crossover (LP)
Subsonic Filter
1 Channel Operation
Advanced Class-D
Bass Engine®
Continuously Adjustable Gain Control
Cross-Vented Chassis Design
DC-DC PWM Power Supply
Dual Sided Glass Epoxy PC Board
Gold Plated Power Screw Terminals
Gold Plated RCA Input Connectors
Gold Plated Speaker Screw Terminals
MOSFET Power Supply
Speaker Level Inputs
Thermal Managment Processor
Top Mounted Blue LED Power/Status Indicator
Specifications:
Bass Engine®
Bass EQ Frequency (Fixed): 50Hz
Bass EQ Level (Selectable): 0 - 12dB
Crossover Type: 24dB/Octave Low Pass
Low Pass Crossover Frequency (Selectable): 50Hz - 200Hz (1/6 oct. Steps)
Subsonic Filter Range: 15Hz
General
Frequency Reponse: 20Hz-200Hz (±1dB)
Input Impedance: 10k ohm
Input Sensitivity (for rated power): 0.2V - 4.0V (1.0 at center detent)
Power Requirements: 14.4V DC (11V to 16V)
Signal to Noise (S/N): 90dBA (referenced to rated power)
Slew Factor: greater than 5
Speaker Impedance: 4 or 2 ohms
MAX Power (at 14.4V, EIAJ)
Brigded into 2 ohms: 700W x 1
RMS Power (at 14.4V, 20Hz-200Hz)
Per channel into 2 ohms: 300W x 1 (0.3%)
Per channel into 4 ohms: 200W x 1 (0.08%)
Edited by Rav
