i thought of this today while defect-proofing my car.
-remove the bonnet stand
-friendly hwp officer (concerned about harmful emissions) wants a look at your under bonnet party
-gets a tired arm from holding up bonnet
-cant get head down to have a good look around the engine bay
-can no longer hold up bonnet
-lets you go and defects your oversize wheels instead
no bonnet stand ftw!
https://www.sau.com.au/forums/topic/244942-avoid-defects-guaranteed/
They will probably send you for inspection over the pits at a later date..
why cant they be friendly copz? "hey mate, sorry for the delay, im required to perform this breath test as part of our drink driving preventative measures. thanks, you can now be on your way. nice 'line by the way."
i would be the nicest cop ever. id harass commodores with mismatching wheels, and unroadworthy shitboxes. oh and hatchbacks with cannons.
:( If only it was that simple.
Actually funny story once, after i sold my s15 for a new BMW 325i I was pulled over for a breath test and the officer was soooooo polite; completely not what i was used to.
He called me 'sir' and i had to quickly glance at my passenger seat to make sure i didnt have anyone else with me lolz!
Im thinking jeeeezus the day I dont have a sportscar im 'sir' all of a sudden, better change then "licence, pop bonnet, bend over, blow in this." lolz
Bend Over??? WTF!
What's BEND OVER got to do with it? :(
Obviously you've never been pulled over by more then one officer at a time...
obviously it was light-hearted in nature. if they were determined to reap revenue from you im sure a missing bonnet stand wouldnt stop them.
Lolz when they search for internal contraband.
Now you know what they mean by the long arm of the law!
Cop: Ok you'll feel some pressure, Im just looking around
Victim: For what a parking spot, get it out
OK sorry Johnny,
Signing Off,
Generation 'W'
take the bus ahhaha true... yeh a few friends of mine years ago in some serious vl's used to say the bonnet release as stuffed so they would get a $75 fine, could been alot worse with everything under the bonnet counted, but no defect.
comin back from melbourne in the 33 with the mrs, got pulled over 3 times for RBT one stop had at least 2 cops, they were all grinning but the lady cop was nice and i didnt get anything.
Drove my mums beemer out in town once, cops did a u turn, followed me for ages, pulled me over to ask me whos car it is. then breathe tested me, searched it etc. the day i got off my p's not even the slightest glance.
hmm the fact that they make U open the bonnet is one thing thats wrong with that and the other is that if u dont have a bonnet stand they will make U hold it open so u will b the one with the sore arms from holding it open :P
yeh but i hurt my shoulder at work and cant do any heavy lifting...
they cant make you open the bonnet or hold it. if they want to have a look then they can do so all by themself. last time i popped it, but the cop actually went to the front and lifted it i think.
next time im going to flat out refuse. i figure they cant actually forcibly open your bonnet without a warrant, and i can easily say, "do you do this to everyone you pull over? no? well, ive got more important things to do, you can admire my car another time. good day officer."
Prior to that, what if you can't find the bonnet-release ???
That actually worked for my wife, she was coming back from work in the 33 and got pulled over. Knowing that since she was driving a "pick me" car much like the harassment we got when whenever we drove the Torana around.
But this time since she'd never popped the hood, she didn't actually know where the release leaver was. (albeit she didn't open her eyes to look for it). The nice Mr Plod, got annoyed with her and just let her go with a few words of advice about modifications.
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
