hi guys & girls
i have the following for sale. preffer pick up, but i can send if its worth it to you.
r34 triple gauge cluster (gauges only, no surround cover) used condition $40
r34 fuel pressure regulator. used condition $10
r34 traction control throttle body (only good for tcs motor, body is hacked up) $10
r34 air flow meter (pink sticker, good for pod filter only as square section has been cut off) used $50
r34 timing cover used $30
r34 stock turbo (only good for housings front +rear...no shaft/blades) $30
r34 stock rubber intake tube. used. $10
R34 turbo heat sheild. used. $10
r34 wastegate modified braket. used. $10
r34 stock fuel rail and injectors. used. $90
r34 amber front blinkers. used. $20
r34 amber side blinkers. used. $10
r34 bare intake plenum top and bottom sections. used. $100
r33 6 stock injectors (one missing the plastic at bottom, see pic). used. $40
r33 amber side blinkers. used. $10
pick up is Dharruk just near rootyhill
i need this stuff gone, if not sold here it will be put on ebay, so all offers considered.
Justin
0408 589 335
Shotgun the...
-fuel p reg
-turbo
-intake pipe
-heat shield
-wastegate
-and 34 fuel rail + injectors
Message and pm sent!
Payment made!
Thankyou
Edited by chriz
  • 5 months later...
Any chance of the TCS motor still available ?
yes its still available, as stated its good for the tcs motor only, the round pipe section has been cut.
Thanks
Justin
turbo still available by any chance?
thanks
no sorry
turbo sold
turbo heat shield sold
wastegate actuator sold
r33 injectors sold
r34 fuel rail+injectors sold
turbo rubber intake tube sold
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
