When cold, it hunts and the VCT solenoid actuates on and off. I believe the cam advance causes stumble increasing the hunting. If I disconnect the VCT, it still hunts but no as bad.
After it warms to operation temp (80 C +) it will hunt less. Once it stabilizes, it idles fine. Blip the throttle and it will hunt.
If I turn on the A/C, it shoots to about 1200 RPM.
I've cleaned the AAC and MAF. I tried 3 times to find vacuum leaks with a can of spray cleaner. I've replaced vacuum lines. I swapped out a spare AAC. I've checked all the intake pipe couplers.
I replaced the igniter (holy fluxing expensive for 6 transistors!), coils and spark plugs.
My tuner looked at it, he checked the timing and used cleaned to test for a vacuum leak this afternoon and thinks its the AAC valve. According to the PFC display everything is fine. I'm setting up an appointment repair tomorrow because I'm getting madder each time I attempt to troubleshoot. He has no clue because the symptoms are vague.
It drives fine, it just refuses to idle. I'm pulling my hair out over this.
Any ideas?
https://www.sau.com.au/forums/topic/244964-idle-hunting-yes-ive-searched/
are u sure? does VCT under SENSOR SW CHECK illuminate at idle?
VCT is only meant to engage when the following are true
NTR is not ON
THR is more than 0.30 (ie not closed)
RPM > 4700 rpm
i dont see how VCT would be on at idle, unless you have throttle open and not in nuetral (or something is broken)
but either way it just sounds like theyve done the self idle learn wrong
no biggie - read the PFC FAQ in my signature and away you go - takes about 30 minutes to do yourself at home, but youll loose the tune
make sure you copy down the tune before you do it
The RPM's increase and that turns on the VCT. The VCT causes stumble under light acceleration. The stumble drops the RPM's. The AAC tries to compensate and over-corrects. Repeat.
I don't think Fujii did the tune wrong, he looked at the PFC display twice already saying all readings are withing normal parameters. I don't like the idea of messing with a $1200 tune.
Welcome to the wonderful world of PFC's terrible idle control, random doesnt even begin to explain it.
What I find has the biggest effect on the idle when you have a PFC is the TPS sensor, you need to get it JUST right and it will idle spot on, also that you have the throttle stop set just right that its not having to use the AAC to compensate more than it has to. In your case if the VCT is kicking in its a sure sign the TPS voltage at idle is to high, dont change the map just set it down just a hair at a time till the problem resolves.
With all my SR's and RB's im doing now im fitting VEMS managment, I got the last car i did to idle without any AAC better with the the VEMS than my car ever has with the PFC, though I must admit I find the idle on the D-jetro system better than L-jetro.
Edited by Rezlo
so again, you are saying that VCT is coming on at idle?
this is not correct and not by design - ie something is broken
VCT should not engage at idle - so if you can fix that, youll probably fix your problem
the PFC idle either works or doesnt, generally when it doesnt work the engine is at fault
ie a toast sensor, a toast mechanical part etc.
If you are running a charcoal canister, block the hoses with a pair of pliers when it hunts and see if this corrects the issue.
Unplugging the VCT and idle change are a by-product of one another, unplug the TPS and the idle will change too, that doesn't mean the TPS is faulty though.
Paul, not sure how the PFC does it, but I know the factory computer on the R33 GTS-t runs the VCT OFF at RPMS BELOW 1050RPM, so it's on above 1050RPM, UNTIL, it hits above 4750 from memory it is, where it switches off again.
It actually sits and idles with VCT off, should come on when revs go higher then 1050... Hence, if it's hunting, it's reasonable to expect VCT should kick on and off if RPM is going above and below 1050RPM, UNLESS the PFC doesn't follow the factory computer setup.
I set up an diagnosis appointment with my tuner for next week. We set a initial price limit of 50000 yen to search for the problem.
How do I copy the tune if I don't have the PFC software? Can I get the info off the hand controller?
My main issue is that I'm leaving Japan and I cant take the car. I've spent way too much on this car because I expected to be able to stay at least 3 more years. I know I'm going to get screwed of the sale but if it doesn't impress a potential buyer the first time, it wont sell. A jacked up idle will turn away any buyer.
1X screwdriver
1X person in car watching TPS voltage
2X Minutes working, drop it by .1v at a time, usualy its only SLIGHTLY higher than it should be.
= corrected idle
99.99% of the time its the TPS voltage that is to high that makes the idle do that on the rb25 w/pfc.
Holy crap my problem is exactly the same as this, i can hear the vct solenoid clicking on and off, and the idle hunts around. Just had pfc put in about a month ago. Been searching for vacuum leaks (none) cleaned and adjusted my aac valve, adjusted tps (but by adjusted i just went straight to .35v, didnt try it on different voltages) and it still hunts around!! Please keep updating this thread (i will too), we should work together to solve this shit of a problem!!!
I'm going to try Rezlo's method and gradually adjust the TPS tomorrow after work. One of my neighbors gets all butt hurt if the car idles (or attempts to) in my parking area for too long.
Me too. Ill adjust mine and post up how i go. Let me know how you go too. I just tried the charcoal canister blocking off, no change.
Edited by RB JET
TPS adjustment didn't do much.
The PFC displays X.XX volts DC. I don't know how many decimal places the PFC actually reads voltage.
If I had the software and cable, I would save the tune and reinitialize the idle. I'm positive that's what it needs because off throttle its great and boosts over 18 PSI with knock readings well within limits.
I hope Fujii can fix this.
I'm positive it’s the idle learn on the PFC or the TPS setting. It's not the TPS, I installed a spare.
I disconnected the AAC and it wont idle high with the A/C on.
I disconnected the VCT solenoid and it wont idle hunt after blipping the throttle.
I disconnected the TPS and the idle is fine and the VCT will not actuate.
It’s a killer street motor. Fast response, about 350HP at the wheels yet drives like a kitten if your foot is not in it.
Basically it’s a great car if its not idling.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
