Hey guys,
Getting a new rear wheel bearing for the R34. It seems no one has done this on these forums and written about it.
Can any one advise on if the bearings listed on ebay will also fit a R34? I will post the link.
I have already ordered from Victoria and fingers crossed it will work.
Can anyone confirm?
http://cgi.ebay.com.au/NISSAN-SKYLINE-SILV...rts_Accessories
The seller is 99% sure it will fit and tells me the shaft size, does anyone know the shaft size for GTT rear wheel?
Its meant to look like this
http://www.skylinepart.com/ekmps/shops/jap...es/img_1316.jpg
Anyone help?
Edited by DECIM8
https://www.sau.com.au/forums/topic/244969-wheel-bearings/
Nissan are useless. Went from quotes between two places from $255 and $280 they would match it at the other place however.
Rockdale Nissan would not supply a product code and was anoying the shit out of me, however with a VIN Artarmon will match it, Thank god!
Anyway thanks to all who helped, Bearings aftermarket dont exist for the R34!
Cheers
Nathaniel
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4266253
did you then click the find part number? Because thos numbers there arnt actual part numbers just a description, as they are both hubs for example.
You're right, i bollocks it up. Ignore previous post.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4268697
Got the Part number from nissan today (had to pay $255 to get it.. i.e buy the part before they would supply a code - have to love Nissan)
The part number supplied was correct, however a friend has installed it on his R34 and the bearing is the wrong size. He made a fitting to fit within it.
Looks like a giant game of shambles.. I am not looking forward to fitting it.
Thanks again for the help Kotter
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4271958
is 255 for both sides of the rear or just one?
jebus...
also why are you replacing them? i've never heard of the wheel bearings go in any skiz to date, unless they were smashed.
On a side note, make sure you correctly fit them. Buggered wheel bearings = wheel comes off
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4272056
Just one.. Ball bearing in a housing rip off! Cant drive it like this tho!
Yeah they are buggered as atm .. So will have to put them in correctly.
I hit a curb, drive with bad camber and often use the handbrake.. this is why.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4272643
had a front left go in my gtst. It's not uncommon. The front right in my s13 sounds like it isn't too healthy either.
They will all let go eventually. Add extra load (track work, big offset) and it will be sooner rather than later.
Seriously though. All the bearings in the car will most likely be manufactured by NSK. And all of their bearings have a number stamped on them. Take that number to any bearing supplier and they will be able to get the right one.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4274166
  • 1 month later...
from memory 38-40mm shaft i believe.
you should really replace both sides mate as if ones gone other wont be too far...... you can get a much cheaper price from bearing places than nissan as ntn supplies bearing for nissan so same thing just maybe diff part numbers
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4358831
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
