check this thread out for info on the prep!
http://www.skylinesaustralia.com/forums/sh...&threadid=20771
and no, this was my first attempt!! turned out pretty good if i say so myself :/ the prep took me a while, but worth the effort! i bought a book on the prep work, but didn't read it :D just pickeed it up here and there from talking to people!!!
PM me or email me if you have questions etc.
  • Replies 73
park next to a new falcon in that colour, see how close they are!!
can give the paint code for that no worries!! yeah black is a little hassly to paint over !
but the colours do look very close, bit of a shame can really see the gold pearl on the car and the stripes very well!!
Nah left the engine bay black, will look cleaner overall!!
and way way less work!!!
engine bay still looks pretty standard, polised the engine/cam covers with a drill based buffer but thats about it!! will post some if you still want them!!!
  • 3 weeks later...
that is one nice paint job! My mum recently bought a new Toyota Echo (don't laugh, i know it's crap :P but it's our 4th car) and it has a pretty damn cool paint job, blue/gold. In one light it's blue, in another gold. It looks pretty awesome even if the car is a piece of junk :S
But yeah, AWESOME paint job. Seems your hard work really paid off!
  • 1 month later...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
