r33 gtst passanger side power window motor and reg complete perfect working order $150
standed r33 turbo exhuast turbo back $100 perfect condition
stock side mount intercooler with all pipes $100 ono
r33 gtst coupe passanger door minior dint easy fix $100 comes with glass
crank angel sensor $100
plenum $100
startrmotor/alternator wiring loom $50 ono
series 1 throttle body $100 ono
series 1 spoiler perfect condition $50 ono
series 1 headlight has small crack in parker light lense $50 ono
rear steering rack $50 ono
set of 300zx stock rims with tyres about 80% plus $250ono
r33 turbo clutch still has nice meat with presure plate $50
contact via pm or 0412 151 213 pickup or post
Edited by rbgtst
plenum $100
few things to add to the list
r33 gtst engine mount brakets $50
r33 gtst throttle position sensor $40
nismo seatr belt covers (not fake) $20
stock boost gauge sensor (part that sits on strut tower) $30
afm that is gutted of all its inside free to good home
plenum $100
BUMP..
plenum $100
BUMP..
plenum $100
  • 1 year later...
hey mate
do u by any chance still have da stock exhuast if u do were about r u located
thanks
Edited by ghabz
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
