That's GREAT NEWS indeed... I'm very surprised about the 'undamaged' bit - makes me think that the guy who took it was a pro, but n00bed out after he got it (hence the discovery).
Was a culprit ID'ed and apprehended?
  • Replies 43
wow
tahts really good news
lol...are u sure u just didnt park it sumwhere else and forgot?
ahaha joking
but seriously...i hate that some people go and do stuff like that...taking other peoples hard earned stuff
such a shame
It was found at Allambie shops (my local shops).
I'm now considering a GPS tracker?
Yeah get that... But also an alarm to alert people and something better than just the standard 3 point for insurance approved stuff.
Kill switch hidden somewhere too would be good!
Great to hear you found it mate... but like many others here I'm shocked the car was taken from there... I park there all the time and always thought it was safe.
...which means I'm afraid, that the rock-spider is still out there somewhere! ...lurking ...lurking bum.
No wires cut, no nothing which is surprising.
I think the Mall is still a pretty safe place to park, I mean a car can be stolen from anywhere really.
When I spoke to the Manager of the Mall security she was surprised, and said they only have about 2 thefts a year (which is pretty good for a huge shopping centre like that).
All's well that end's well !!! Congrats!
Tez
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
