Not really pointless IMO as it shows how much a step forward in performance from the factory the R35 is, by comparing it to well regarded and tuned examples of former models
I've watched the DVD and at the end tsuchiya makes the remark that the r35 was faster in the corners, just the long straight was what kept the tuned cars in front
Edited by Yo-Yo
Best Motoring GTR Loaded DVD.
I got it and watched that race and it was nuts.
R32 GTR 400PS
R33 GTR 600PS (2.8lt stroker kit)
R34 GTR 600PS
R35 GTR Stock
At first I thought it was abit unfair to the R35 as all the other GTR's were tuned, but judging from the finish times, it came 3rd and the times were very close, all within a difference of seconds.
As for the R32 GTR, with only having 400PS, it still kept up very well and kept the race tight.
As keiichi Tsuchiya was saying, the tyres were starting to wear down and was slipping / lossing traction, which I believe due to the weight of the car and every setting set to R Mode, it gave the car a good thrashing.
Just goes to show how a stock R35 GTR can stand its ground up against highly tuned GTR's and only afew seconds slower is very impressive.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
