Ultimate Gt-r Battle
SHANE666
 Share
Not really pointless IMO as it shows how much a step forward in performance from the factory the R35 is, by comparing it to well regarded and tuned examples of former models
I've watched the DVD and at the end tsuchiya makes the remark that the r35 was faster in the corners, just the long straight was what kept the tuned cars in front
Edited by Yo-Yo
Best Motoring GTR Loaded DVD.
I got it and watched that race and it was nuts.
R32 GTR 400PS
R33 GTR 600PS (2.8lt stroker kit)
R34 GTR 600PS
R35 GTR Stock
At first I thought it was abit unfair to the R35 as all the other GTR's were tuned, but judging from the finish times, it came 3rd and the times were very close, all within a difference of seconds.
As for the R32 GTR, with only having 400PS, it still kept up very well and kept the race tight.
As keiichi Tsuchiya was saying, the tyres were starting to wear down and was slipping / lossing traction, which I believe due to the weight of the car and every setting set to R Mode, it gave the car a good thrashing.
Just goes to show how a stock R35 GTR can stand its ground up against highly tuned GTR's and only afew seconds slower is very impressive.
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
