hey guys and girls i have full vertex bodykit sitting at my mates house and i just cant be stuffed fitting it myself, i was wondering if anyone knows a place that will fit the rear bar and side skirts fast and cheap? as i dont get much time to myself anymore.
cheers
ooh and nothing needs to get painted as im still trying to find a gtr front end then ill respray the whole car at once.
Edited by aahh32
https://www.sau.com.au/forums/topic/245001-where-to-get-a-bodykit-fitted/
cheers
all type crash have done a few kits on 32's
M&C Doyles
One of the best places that specialise in bodykit and resprays.
If you want a professional job, Doyles is the go mate.
I wouldnt trust anywhere else besides Doyles to touch my kit or paint.
Nate.
lol its not hard to fit a kit..
M&C Doyles
Nate.
haha funny
i wouldnt even think of doyles now seeing some of the work that has come out of there lately since two of there best have left and gone elsewhere
but all to there own
i would personally go to all type or eagle crash
M&C Doyles
Nate.
someone on this forum had some crash repair work done by them not long ago and lets just say it wasn't very impressive at all.
depends on the kit and how much work is required to get the kit to fit. with mine my regular body shop didnt wana touch the kit seeing it was fiber glass. where doyles made it fit, modded where needed no probs.
they have done A LOT of kits and know their shit. their paint on the other hand.. average.
Not generally but it really depends where the kit came from...
Maybe post up what area your in so people can recommend a workshop near you. Both Doyles and All Type are decent but also at opposite sides of Adelaide etc.
Ryan
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
