I recently purchased one of these Autobarn88 Intake pipe kits for my R32 GTR.So I thought I would tell a cautionary tale about my experience yesterday.
Lets begin.
I came across the kit on the performance-wise website and thought " hey why not give this a go? "
The Intake kit is advertised as a 'bolt on kit' but, it's far from one.
Yesterday I started the morning in the sunshine under the bonnet of the R32 GTR striping out the factory intake bits with the new parts laid out on the grass ready to go in.
The first and most obvious indication that things are not as they seem is in the instruction leaflet. Well 'instructions' would be a misleading term to apply to what is basically just an inventory list and for those who need some instructions you would be up the creek (not a big deal for me though).
The first indication that the kit isn't 'bolt on' is there is a page in the booklet that has a pic and an instruction to relocate your power steering tank to the front of the engine bay. Well thats not to bad you might say. But, you will need to pop out and buy some new transmission oil hoses and clamps.
You will find that isn't the only set of hoses that need purchasing in order to 'bolt on' the kit. You will also need a new longer oil breather hose. You will also need some new factory BOV recirculation hoses although that part of the design is so flawed you might like to go out and just buy an atmospheric BOV kit and plug them.
The first snag I ran into was the front intake pipe that attaches to the turbo. It won't go on. It hits the power steering pump.
Being a good little modifier I was not detered. I got my die grinder out and sanded off a few mm of alloy to give clearence and then on it went. Hurrah and Huzzar I said. :P
I then noticed that the rear pipe (the one that necessitates relocation of the power steering pump) has need of a much longer oil breather hose (off to the shops) and it also has a rather large nipple for the very small vacume line pickup. So I threaded in a brass nipple for that. At this point you can tell I am one of those 'positive' people, most would have boxed everything up by now and started drinking and cursing, not me (well not yet).
After bolting that one on I then went to examine how the recirculation pipes for the BOV went together. Oh dear. The supplied T peice and the replacement elbow (replace the factory single all in one metal pipe) require new custom length pipes at first glance. I fortunately have access to alot of the correct diameter pipes that can be trimmed down (lots of GTR parts).
This is where it began to dawn on me that the china kit was never going to fit. EVER. You see, you simply cant use those bits. I tried, with access to more fittings than most. In the end you couldn't get this to work even if you cut and rewelded the pipes, I actually thought about it. :(:D
I thought for interest sake before I went making any new pipes up myself I would dummy fit everything else. Here is the most condeming part of this mystery.
* The front intake pipe ,that required power steering pump machining, Points straight into the recirculation pipe with the AFM attached --- Not going to happen. It also required a custom length bolt for one side of the connection to the turbo (not supplied I supplied one)
* The front turbo outlet pipe also ends up pointing into the recirc pipe, all roads lead to recirc pipe.
* The Y collector angles have no relationship to joining with anything in the kit, in so far as the outlet pipes want to point at something else, in most cases the recirc pipe. In China that spot in your engine bay has good feng shui no doubt.
I have applied to get a full refund from Performance-Wise, so I will keep an update on this part of the review.
In summary my review of the experience is as follows;
# Paul at Performance-wise is prompt, friendly and professional. ******* 3 stars for Service so far.*****
# The Performance-wise website is HIGHLY misleading about the product ***** 0 stars for product info *** :down:
# The KIT is a giant chinese practical joke :D *** 1 star , I can see the funny side but, I'm not laughing yet ** :down:
My advice is that this kit ,even if it worked, is so poorly designed that it should never have seen the light of day in manufacture. There is simply no need to have to re-locate the power steering bottle to achieve the result.
Is this the last cheapo china part I will ever buy? Who knows?
If people think it would help to have some pics to laugh at let me know and I will post a few for amusement. remember this is a good example to bring up next time you argue with me in a topic thread :D
Edited by rev210
  • Replies 94
to much essay, not enough pics.
without reading it all, who uses ebay/china parts on a gtr?
factory setup is good to 300rwkw, after that a core upgrade might be required.
maybe you have a big single upgrade and needed this kit, i'm not sure?
You asked for a kit and got a kit. Quit complaining. Ok, well, it isn't obviously for a GTR but hey, it's a kit right ? I to have bought kits before and let me tell you unless your tongue is hanging out the left side of your mouth and your using a left handed screw driver it isn't going to work. I did four years of university to learn this so I can't be wrong. Clearly there are other flaws in your mechanical skills. Did you lubricate the mechanic with the appropriate beverages, ie: beer, bourbon or mud shakes ? Some of these air filter and intake kits need to have the motor pulled for clearance while using chinese spanners, you do realise you can't install a chinese kit wthout chinese spanners don't you ? Please dear God in heaven you did use chinese spanners ? Really, I don't know some times. You guys kill me. You think you know it all but your just fooling yourslves. Did you at least have a flee bitten blue heeler under the car licking his bollocks while scratching his ear with his back foot ? You do see my point here don't you ? I hope so because I can't. ;)
And they wonder why our balance of payments trade with china is so one way!!!
I had a similar try with a GTSt unit years ago,,,,it also ended in failure, arguments and after legals and threats a partial refund [that business now no longer exists]. I wish you luck!!! And I'm with JoeyJoey on this, no china parts.
My china knock off of the Greedy inlet on my 25 works a treat, Sorry that you got screwed, Some stuff is good some stuff aint, I have a problem with the amount of money some companys charge, I know that R % D costs money but its a joke when these items are developed years ago and they still charge top dollar, if the big companys items were at least more competitive price wise they would get my money, which they do with some items.
When i shop i dont go out looking for brand names i go out looking for a part, compare price, quality, then make a informed decision.
Chinas fabrication has evolved 100 fold over the last couple of years.
Also if a comany in Australia says its a bolt on item and its not you return it and if it is a good company they will fix the problem, if not ring fair traiding and get it sorted.
My 2 cents.
Clearly there are other flaws in your mechanical skills. Did you lubricate the mechanic with the appropriate beverages, ie: beer, bourbon or mud shakes ? Some of these air filter and intake kits need to have the motor pulled for clearance while using chinese spanners, you do realise you can't install a chinese kit wthout chinese spanners don't you ? Please dear God in heaven you did use chinese spanners ? Really, I don't know some times. You guys kill me. You think you know it all but your just fooling yourslves. Did you at least have a flee bitten blue heeler under the car licking his bollocks while scratching his ear with his back foot ? You do see my point here don't you ? I hope so because I can't. :D
damn I knew I wasn't drunk enough aaand I was using taiwanese china-copy spanners. They aren't made of easy break copper with chrome spray paint.
Doh!
mlr,
I hear what you are saying,the thing that hasn't evolved in china fabrication is quality control. It's too hard to throw out the production line rejects when some westerner can be stitched up for a dud or two. They don't care because life is cheap and short.
Paul at Performance-Wise has been right onto this issue for me so I'm sure the outcome will be fair.
Awesome write up mate.
I have a feeling I know what the bulk of your issues were though, I have seen those Autobahn88 kits, they are copied directly off the Greddy version, and Autobahn88 only makes them for R33/R34 GTR, so if you were sold one for R32 GTR, I reckon thats a big part of your problem as they are very different.
Nick
You asked for a kit and got a kit. Quit complaining. Ok, well, it isn't obviously for a GTR but hey, it's a kit right ? I to have bought kits before and let me tell you unless your tongue is hanging out the left side of your mouth and your using a left handed screw driver it isn't going to work. I did four years of university to learn this so I can't be wrong. Clearly there are other flaws in your mechanical skills. Did you lubricate the mechanic with the appropriate beverages, ie: beer, bourbon or mud shakes ? Some of these air filter and intake kits need to have the motor pulled for clearance while using chinese spanners, you do realise you can't install a chinese kit wthout chinese spanners don't you ? Please dear God in heaven you did use chinese spanners ? Really, I don't know some times. You guys kill me. You think you know it all but your just fooling yourslves. Did you at least have a flee bitten blue heeler under the car licking his bollocks while scratching his ear with his back foot ? You do see my point here don't you ? I hope so because I can't. :D
I really shouldn't have read this post while drinking my coffee as half of it is now on my keyboard :D
japanese parts good. chinese copy parts bad.
this is tattooed to the back of my right hand, so that as I'm about to click "order" with my mouse I ensure i'm making the right choice.
the problem is chinese bits may be a little cheaper but in the end you spend more time fitting, more time modifying, often need to buy extra bits to fit, and in the end you end up with an inferior quality of part and an inferior installation that if you had just bought the japanese part in the first place. so in my eyes there is no saving at all. and if you factor in your stress and time etc i recckon the cheap parts "cost" you more...
Bit of a blanket comment there Richo.
The Cooling-Pro Alloy Radiator I ran in the GTR certainly didn't fit the picture you describe - I gave one a go and wasn't disappointed.
Well priced, dropped straight in, has run solidly in a 400awkw GTR without a hiccup for well over a year now.
And not forgetting I am very very anal when it comes to the parts that I fit to any of my cars.
SOME china bits are ok. However if i do use a "china" made product on my car it has to have a very good reputation or been proven many many times over.
I have a "china" made intercooler on my car that has been there since i started all my mods. But they are pretty much all made in China these days.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
