I picked up a half finished RB20 project a few weeks ago. It's an A31 with an R32 motor and a C33 KS-ROM ecu...(?) It has extra electrical connectors. I can't find a wiring diagram for an A31. The car runs and idles but is difficult to start. Any ideas?
Left to Right:
8pin with only 2 wires: sky-blue & green/orange.
2pin: brown & black
2pin: white & black
Extra cable.. probably doesn't go to this car.
Looks like an injector resistor, but the connector is hacked off and shorted together.
Nothing connected to the air conditioning.
https://www.sau.com.au/forums/topic/245015-extramissing-harness-connectors/
right, i think your first photo is showing the old anti lock braking system plugs off the half cut loom. cant quite see if one of those plug has fibreglass insulation on it, if it does it will be the o2 sensor in the out let manifold. the shot with just the plugs one of them looks like the loom which used to go to the old auto trans and the othe one looks like the plug which brings power over to the computer and the power from the dropping resiter for the injectors throuh the head light loom. if it is running though it shoud be sweet and not need the othe wires. not 100% though, good luck! definately a injector resister in there, not sure of the rb20 but the 26 needs a injector resister with 7 wires coming out of it, so not needed.
Left to Right:
2pin: brown & black
2pin: white & black
Green/Orange Neutral Switch (44)
Light Bluish/Green A/C Cut (9)
  • 4 months later...
  • 3 weeks later...
that plug with just 2 wires left ive got a face lift ceff loom in my non face lift and was told i had to cut 4 of those wires up and join them with that plug but only 3 of them are the same colour ????
I have no idea.. I'm still trying to figure out how to wire my aircon.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
