Genuine Sale!
WRX MY98 built-date 05/98, white colour, 165KW ATW (more if needed) with dyno sheet
meticulous 3rd owner, all books, all receipts,
serviced regularly,accident free!
Car is pampered!!
80,000kms, RGB779, NEW reg till 09/04 - $28,200 obo.
** or $27,000 without gauges **
!!! $26k with standard wheels now!!!
Open to REASONABLE OFFERS!!!
In Melbourne, SE suburbs.
http://www.pbase.com/rexwrx/wrx98
Call 0411673005 or email [email protected]
Exterior
- Genuine STi rear spoiler
- All colour-coded white
- Genuine STi clear rear lights
- Replica 22B style front bumper
Rolling-stock
- Rays Engineering Volks TE-37, 17"x7" rims with Bridgestone R-rated tyres
- Apexi T-Max struts (adjustable dampers) with Apexi lowered sports springs
- Whiteline 22/24mm front-sway bars and 24mm adjustable sway bars, both with heavy duty mounts
- Whiteline Anti-lift Kit
- Whiteline Camber-Kit
- Cusco Front and Rear strut bars, adjustables
Brakes
- Genuine 4-piston STi calipers with Comp9s pads (FRONT)
- DBA 5000 slotted rotors with aluminium hats (FRONT)
- Goodridge Braided Lines (FRONT)
- DBA slotted/crossed-drilled rotors with RB74 pads (REAR)
Engine,Drivetrain,& ECU
- HKS Type-S Front Mount Intercooler Kit, with waterspray
- HKS Mushroom air-filter
- Autronic Plug-and-Play Computer with anti-lag setup
- Apexi Hybrid VF22/23 Turbo
- Trust Full 3" turbo-back exhaust
- Walbro Upgraded fuel-pump rated 400HP
- Lightened and balanced flywheel
- Heavy duty Button clutch
- Blitz blow-off valve
Interior
** Optional Gauges **
- Apexi EL2 Gauges: Boost, Exhaust Temp, Oil Temp, Water Temp (All have playback modes, max-reading,etc)
- Short-shift (adjustable)
there's no body kit, other than the original STi wings. everything else is colour coded.
as for the front bar, it has to be 22B style front bar because of the Front Mount intercooler.
i need to sell the car, and it's an excellent car with CLEAN history!!
I've pampered this car too much and sadly, i've to sell it now.
anyone interested, please feel free to come and have a ook....
MUST SELL!
thank you guys.
i just need everyone to pass on this message to those whom you know who is after a WRX, modified WRX to b particular.
i've had plenty of queries, but only one serious offer. Though, in the end the person pulled out as well due to his budget constraints...but he had come a long way from WA.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
