Okay so here it goes
I was wondering what are the best conrods to use in a 1000hp rb26dett. What is the best option. They need to handle 11000rpm and 2 bar of boost and more. Need some sort of idea! ;)
Edited by two_evil
https://www.sau.com.au/forums/topic/245045-what-conrods/
  • Replies 40
What would be the best of the best rod? and what would be the bare minimum. from what i can gather at the moment eagles are the minimum that i would be comfortable using. i would like to have a little room to play with
Edited by two_evil
https://www.sau.com.au/forums/topic/245045-what-conrods/#findComment-4264484
jun carillo argo
x2 and for bolts id recommend ARP L-19 items...the best!
i use JUN and will be making in excess of 1000hp...Mark uses Carillo and he makes well in excess of 1000hp...and id also use Argo as they are designed and made not far from where i live (i like to support the local product)
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/245045-what-conrods/#findComment-4264603
The engine had a set of really good looking (beefy strong) Jun rods. The problem i had is that they are 10 grams difference in weight from the heaviest to the lightest and the machine shop were a little concerned. they also said there are slight marks on them from something. So this is why im enquiring. If i need new rods i know which to buy. should know by tomorrow. Fingers crossed i don't. Would like to save a little bit of money :D Also where would be the best place to purchase a set of carillo or argo rods
Edited by two_evil
https://www.sau.com.au/forums/topic/245045-what-conrods/#findComment-4264617
saving money and 1000hp dont really go together imo.
Best off trying the US for the rods and I would speak to Carrillo themselves because from memory the have a couple of different Grades of Rod
http://www.carrilloind.com/
https://www.sau.com.au/forums/topic/245045-what-conrods/#findComment-4264636
sounds like what ive just built...
im using Eagle rods :D
I dont see the point in spending over double on pauter or Carillo, ive used eagles that hold 600kw in SR20's and well over 1000hp in 2jz's, B series at over 500kw (highest hp rb ive done is only 800hp also on eagles :-(, granted its an every day street car )... in 99% of cases its usualy the pistons or oiling system that fail before the rods, if you got the money to burn why not, but if your on a budget like most people I see nothing wrong with chasing 1000hp on eagles, spend the extra on the oiling system....
https://www.sau.com.au/forums/topic/245045-what-conrods/#findComment-4264820
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
