  • Replies 40
HOLY CRAP 1000HP RB26dett..........
How much it cost to build. I wanted a 23-30 hybrid and was promised only 550rwhp. And it was going to cost me $16K.
Did it cost you a mortgage on the house to get that power, as I have been led to believe?
Not directly on point but when I asked Mark at Mazuroski at Mazworx in the US about whether to use Eagle rods or Manley Turbo Tuff rods in my SR his email response was:
"Anything over 400hp we like to use the Manley's".
My take is that cheaper aftermarket rods will hold a decent hp.....the question tho' is for how long.
honestly, if you can afford to build and maintain a genuine 1000hp RB engine, you can afford carrillo's. :(
This is truth, when you compare price say, 700 to 1700, in the great scheme its nothing. Not to mention if it puts a hole in the side of your shiny new N1 block.
Is there a recipe for a 1000hp gtr engine thats reliable these days? Or is each engine still a an engine that is developed over time, possibly blown up a couple of times till the tune is just right?
Any variation in fuel quality could cause a blow up so such engines would have to be being run on race only fuels, so that 1000hp figure would be an off the street, on the dyno/track figure right?
the 1000hp mark would be with race fuel, still 750rwhp would be good 4 street use or maybe highway :P
Also has anyone here use crower rods before and how do rate?
Edited by two_evil
i went with argo rods, they are very very solid and well designed... have seen them runnning nearly 900rwhp so they are a good thing
i think pauter are great rods but are probably a little of the skinny/light side for 1000hp
as others have stated carillo have a very good name
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
