I've found I go through a few things.
1. Just got into the traffic so I start to stress about being late and the road rage comes on. Start cursing the world and all the retard drivers in it.
2. Call random mates to rant about traffic/road rage
3. CD Gets switched to something heavier and I proceed to rock out in my car. Air Guitar FTW.l
Normally the traffic will start to move after that lol :P
  • Replies 43
I daydream about winning enough in tattslotto that i'd never have to work again. Then i daydream about what i'd spend the money on.
Then i daydream about never having to sit in peak hour traffic because i wouldn't need to be going to work!!!!!!
Baaaaaaaaaaaaarrrrrrrrrrrggggghhhhhhh........ It never ends well.
Play tag with the ricer lancer coupe I always see when I head to the city in peak hour traffic.
Always tries to get in front of me, even when he does we end up back in the same place anyway because of traffic lol
ffs so many people pick their damn nose....its disgusting yet soooooo many still do it...the ones that really are bad are those that are a little hungry at the time....
nb: I dont pick my nose in traffic..I usually file my nails, but my windows are that dark you wouldnt be able to see either way... :banana:
nb: I dont pick my nose in traffic..I usually file my nails, but my windows are that dark you wouldnt be able to see either way... :/
I've even seen women doing it in my rear vision mirror!
Is this an equality of sex thing - or have I just been brought up wrongly, thinking that girls don't stoop to such things?????
Tez
PS This doesn't mean does it that you do it when there's no traffic??? hehe
Tez
Ah Terry, never experianced long nails I take it :D ....regardless of traffic, its a near impossibility...that being said am yet to see a fellow girlie trying to pick a winner...so my sexist view stands!
1. Check what cars are next to you and whether any are worth....well you know....
2. Check if there are any hotties sitting in their cars and whether any are worth....well you know....
3. Realise the lights allready turned green for quite a while cause i've been wasting time with 1. and 2.
Ah Terry, never experianced long nails I take it :P ....regardless of traffic, its a near impossibility...that being said am yet to see a fellow girlie trying to pick a winner...so my sexist view stands!
Oh you girls - you rationalise so well!
You can be in the middle of hacking into a guy :D ; but as soon as you pick up a phone, it's "Hiiiiii, How Are Yooooou! - Great to hear from youuuu! No I'm not in the middle of doing anything special!!...........etc etc." lol :wub:
Terry
Hahaha the 6th sense returns to the 1st sense!
anyone else ever just flop it out and have a little rub? u know, nothing too dedicated, just some gentle affection to pass the time? :P
HAHAHAHAHAHA My mate did this about a month ago on his way home from work on the freeway and it was not as lightly put as you have put it he went the full way, when he told me i almost died laughing .
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
