Scc 08 Pics & Vids
n15m0
 Share
Hi guys,
Thought I'd create a separate thread rather than clutter the existing one. Didn't take many pics this year but as you can see I still have a soft spot for 34s ;)
Hope to see more pics and videos!
  • Replies 92
And of course we can't forget the crazy locals trying to sell their wares
I actually have a video of a about 3mins of the mountain happiness ;) But I'm talking a fair bit of shit over the top of it so I don't want to upload it.
Uploaded 58 photos in total to my myspace
Edited by ToMMaH
just some quick ones off my phone.....
there was some cars with i think VOLK TE37 style rims.....similar to drifteks or something......i someone got some pics of cars with these rims on them....can they plz post them up....need to see them and know the model numbers as i wanna acquire a set....cheers!
Edited by WOG BOY
Hey fellas,
Some of you may have seen 3 guys running around with video cameras we may have even spoken to you about your ride during the day. we are in the process of getting a video together of the day but i thought i may as well post something i thought was quite funny as a bit of a preview :D
THE FIRST SKID OF THE DAY... after he cant find the gear not once but twice... poor guy
http://www.youtube.com/watch?v=fRvkgE6pquc
Bloody panel beater still has my front bar. 3 days? Its been 3 weeks and i also get to miss out on the best day ever. :D Hope everyone had a good day. There are some really clean cars being posted. Keep the posts going. +1 > vids
i took a few was pretty busy most the day helping out thooo..
got home and jumped straight in my pool in clothes and all!! was soo hot!! awesome day though!
i dont care how much it costs me im getting my air con fixed!!
i got a soft spot for 34's too :D
anna banana and meeee at the car park..
Hey fellas,
GREAT - now im watching tranny's on youtube >.<
ZOMFGGG the slow striptease one is making me sick :D nice bulge in the panties and padded bra lol yukkkk
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
