Scc 08 Pics & Vids
n15m0
 Share
  • Replies 92
Round 3
Nice work col, you got some GREAT shots.... I wasn't actually pissed off, although I really do look it :( It's a good pose to do when you're hot and sweaty. Note to self, start diet ASAP :)
178KQT - hks intercooler, 3" turbo back exhaust (not sure what) with split front/dump pipe, K&N panel filter, exedy heavy duty clutch, nismo suspension, hello kitty headrest & drink holders (EASILY worth 30+rwkw) hahahaha basic basic mods, it's only a daily so it was never planned to have any mods :(
cheers col for the great pics of me car mate. the day was a good one, never seen so many skylines in one place at once. it was nice seeing some of the members and there rides. can't wait til next year.
Just wondering what kind of power some of these cars make and what mods they have..?(feel free to add your car to the list i know i have left out alot)
Lets start with the
R34's
R33's
R32's
What about the poor old 31's? They always miss out lol
Were they any r30's or old 8's there? So wish I went but I guess there is always next year! :P
Nope 31s were as old school as it got this time.
Yeah wasnt there a r31 with an rb26 ???
Not that i know of
Me - White on Gold Passage Wagon - RB20ET(yes single cam)
Dean - Brown Wagon - RB30E
Cam - White on Silver sillo - RB20DET
Darkwing - White on Silver Sillo - RB30E
Stubby - Light blue Pintara/Skyline Wagon - CA20E
(cant remember guys name - White 2 door - RB30E
Edited by redlineR31
Lets start with the
R34's
R34GTT
ex HKS Tokyo car with FMIC, ECU, ECV, TURBO, EXHAUST. Running 1.1 bar, no dyno yet!
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
