Lots Of Gtr Stuff - 17 X 9 Rims, Te37's, Dump Pipes, Manifolds, Tyres, Seats, N1 Turbos, Ecu's, Chip, Z32's, Greddy Oil Cooler, Nismo + Z32 Afm's,
Not really keen on swaps - but pm me with some pics anyway.
Heya,
Just wondering if you were willing to swap 18"s for the Te37s?
Bored to suit Tomei Pistons - Tight Clearance (2.2 ~ 2.5 thou) from memory.
The pistons are in another block now...
Will have it mic'd up for a serious buyer.
(I actually have just bought a set of 87 mm slugs so may even end up using it myself)
Tomei run a 1.9-2.2...bloody nice and tight eh...pics of the cusco front uppers please.
Will PM you with pics shortly.
Hi, do you have the nismo afm's still for sale. What is the difference between standard and nismo afm's.
Regards
76gtr
OHLINS SOLD (still have HKS Springs and Cusco Tops)
GIAS SEATS SOLD (Plain ones still available)
ARC AIRBOX SOLD
N1 VENTS SOLD
  • 3 months later...
hey mate just wondering if you still had your hankook and advan tyres? if you do wahts the lowest price you would do for each pair or together? how much tread left?
thanks
jake.
  • 3 weeks later...
can you email pics of cusco upper front arms to [email protected]
do you know what the - rating of these are? or are they adjustable? and if so. how far?
email best form of contact as SAU doesn't work on my home computer... FML
  • 3 months later...
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
