About to put in a new EBC on my GT35 setup and wondering if it matters how far the pressue feed is in relation to the turbo.
I notice on some they tap the fitting straight into the front cover of the turbo, i have mine in the intercooler piping just after the turbo elbow, say 30cmm pipe length away from the outlet of the turbo..
My question is will this affect the response/reading/signal in any way for my boost controller as i am thinking of tapping a fiting straight into the cover of the turbo if neccessary, obviously dont want to have to go to the effort if its not neccessary.
Thanks in advance
https://www.sau.com.au/forums/topic/245094-pressure-line-off-turbo/
its the line that goes from an external wastegate to the turbo - which is bypassed by the boost controller t piece or bleed valve (whichever your weapon of choice)..
in this case im guessin your reffereing to the after cooler before the TB, why is that?
you want the BOOST CONTROLLER lines as close to the turbo outlet as possible. you want the boost controller to pick up pressure as soon as possible.
BOOST GAUGE needs to be @ at the intake manifold to read actual pressure/vac passing through the motor.
EBC's usually have 2 separate feeds. 1 for the solenoid (controller) and one for the unit to read actual pressure.
yeah, put your gauge reading close to the engine intake so you can see the actual pressure that is reaching the engine. put the boost control pressure feed near the turbo outlet to enable quick reaction. but in my experience it doesn't make a massive difference. so if it's convenient where it is now, 30cms along, I'd just leave it.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
