Hey guys, Ive got a r33 gts-t for wrecking here in sydney. It's hit a gutter on the front left wheel so the left LCA, left guard, left headlight and bumper are gone, but pretty much everything else is still here
If you're after any little bits or pieces send me a PM. Pics below
R33 S2 motor:
Approx 121,000 ks, good compression. Comes with turbo, coilpacks, alternator & ECU (p/s and a/c are sold, loom sold/in use) $1600
5sp manual conversion to suit R33/ R34:
Gearbox has around 121,000ks, good condition. Everything ya need.. includes clutch, flywheel, box, tailshaft, master cylinder, slave cylinder + lines, shifter, pedals and gear surround - $1750 negotiable
or Box, slave cyl, tailshaft $1400
R32/R33 Boss kit - $40
GFB boost T controller - $20
Apexi power intake filter - $40
Apexi turbo timer - $80 Works well, plugs right into the r33 ign loom. Should fit R32/R34 as well
HKS fuel cut defender - $50 posted
Chrome/aluminium/silver/whatever door sills - $120 pair
Front & rear strut braces - $150
Pioneer 3-way 6" speakers - 220watt / 60wrms - $60
post-35556-1226836282_thumb.jpg post-35556-1226836209_thumb.jpg post-35556-1226836251_thumb.jpg
Set of R33 gts-t stockies with tyres. Tyres have some tread but the rubber seems a bit shagged - $200
5 stud space saver - $50
5 stud bolt on spacers, 5x114.3 to 5x100. one pair 14mm, the other 20mm
Drivers side sideskirt & rear pod - $80
R33 GTR spoiler + bootlid (lock not included) - $350, pickup only!
S2 drivers side headlight - $200
S2 bonnet (black) - $300
S2 front grille (black) - $60
Side mirrors (black) - $50 each
Tail lights (black) - $60 each
Rear SKYLINE garnish (black) - $50
Rear bumper (black) $80
Rear reo bar - $80
A/C condenser - $150
Front reo bar - 2 small areas cut out for FMIC - $100
post-35556-1226835868_thumb.jpg post-35556-1226836384_thumb.jpg post-35556-1226836418_thumb.jpg
R33 alternator - $80
Fuse box lid - $20
Battery, good charge - $50
Stock cat - $50
HKS super dragger catback exhaust - $250
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel - $80
Stock SMIC & piping - $80
Rear suspension - pedders lowered springs & stock shocks - $100
Front lower control arm, drivers side - $70
Front upper control arms (spare from another car, undamaged) - $80 pair
Front hubs - $70 ea
Rear lower control arms - $60 ea
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Non-abs Viscous LSD diff - $150
Driveshafts $60 pair
Rear upper arms - $50
Front calipers - $250 pair
rear calipers - $150 pair
Rear rotors - $50
Drivers door window switch - $80
Drivers window switch surround - $40
Drivers door motor - $80
Drivers door trim - $50
Passenger door motor - $50
Dash surround (goes around CD player, cluster, etc) $80
Instrument cluster, 121,000ks - $120
Gear stick surround, with boost gauge built in - $60
Under dash piece (covers fuse box) $30
Genuine nissan floor mats, full set - 100
S2 Steering wheel minus airbag, good nick - $60
Front seats, immaculate condition - $200
Rear seats, immaculate - $50
Seatbelts, full set - $60 (will seperate)
Ignition barrel + door barrels + key - $100
https://www.sau.com.au/forums/topic/245103-wrecking-black-manual-s2-r33-gts-t/
  • Replies 75
That first picture you have, is that what people put in their boot? Since i know theres a bar that goes across the battery that i've seen in pictures but i don't have one in my car.
If it is then i'd be interested in it.
Also whats the second last picture?
I have a R33 Series 1, would those parts fit in it?
Edited by Tyson 1990
Hiya, it's a rear strut brace in the first picture. Second last picture is the rear garnish that sits between the tail lights.. they'll both fit S1
  Ten Four said:
pm sent
Replied
  turbo rxp said:
im after the bonnett can u advise me for the freight for post code 3020
Hey mate, i'm just looking for a pickup on the bonnet at the moment as theyre a nightmare to pack up for freighting
HKS FCD and front seats sold
  Sky_High said:
PM sent
Pm replied
  NYTSKY said:
Ill give you $1200 for the box and shifter.
done, pm sent :)
What area in Sydney are you? (PM me)
I'm after the boot trim (red arrow), and possibly the carpeted trim piece behind the sub where the blue arrow is pointing.
I'm after:
- Drivers window switch surround - $40
- Dash surround (goes around CD player, cluster, etc) $80
- A/C Fan if you have it
PM me with details
Pms sent to you guys ^, and all others should be replied to
passenger window and reo bar sold.. drv headlight, bonnet and grille sold pending payment
  dori32 said:
whats the condition of the apexi pod? has it got an adaptor?
if its in good nick & comes with adaptor ill take that and the GFB t boost valve.
pm sent!
PM sent
  PSI Parts said:
Waiting on reply.
Sent
  sIIgtst said:
hey ,
after the drivers side door if its in good nick..
tried to pm but your inbox is full..
Corey,
oops, cleared now. Pm sent
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
