  • Replies 75
  • 5 months later...
Hey mate do you have the plastic bit that fits under the car stereo ? (Skyline R33) http://www.skylinesaustralia.com/forums/po...26-IMGP0142.JPG (example) put the keys and stuff in it... im in Melbourne if you have it might need to post it out or something.
Hello how are you?
First what area you in?
Second i need best price for me to pick up al parts you have out of my list below, this is what i need:
Front bar, headlights, bonnet lock support, bonnet lock, bonnet, grill, radiator, radiator support, rear bar, rear bar irons, both tail lights, boot lid (no spoiler), boot lid lock, fan clutch, ac condensor... think that's all for now. thanks >_<
Dannie
Hey guys, Ive got a r33 gts-t for wrecking here in sydney. It's hit a gutter on the front left wheel so the left LCA, left guard, left headlight and bumper are gone, but pretty much everything else is still here
If you're after any little bits or pieces send me a PM. Pics below
R33 S2 motor:
Approx 121,000 ks, good compression. Comes with turbo, coilpacks, alternator & ECU (p/s and a/c are sold, loom sold/in use) $1600
5sp manual conversion to suit R33/ R34:
Gearbox has around 121,000ks, good condition. Everything ya need.. includes clutch, flywheel, box, tailshaft, master cylinder, slave cylinder + lines, shifter, pedals and gear surround - $1750 negotiable
or Box, slave cyl, tailshaft $1400
R32/R33 Boss kit - $40
GFB boost T controller - $20
Apexi power intake filter - $40
Apexi turbo timer - $80 Works well, plugs right into the r33 ign loom. Should fit R32/R34 as well
HKS fuel cut defender - $50 posted
Chrome/aluminium/silver/whatever door sills - $120 pair
Front & rear strut braces - $150
Pioneer 3-way 6" speakers - 220watt / 60wrms - $60
post-35556-1226836282_thumb.jpg post-35556-1226836209_thumb.jpg post-35556-1226836251_thumb.jpg
Set of R33 gts-t stockies with tyres. Tyres have some tread but the rubber seems a bit shagged - $200
5 stud space saver - $50
5 stud bolt on spacers, 5x114.3 to 5x100. one pair 14mm, the other 20mm
Drivers side sideskirt & rear pod - $80
R33 GTR spoiler + bootlid (lock not included) - $350, pickup only!
S2 drivers side headlight - $200
S2 bonnet (black) - $300
S2 front grille (black) - $60
Side mirrors (black) - $50 each
Tail lights (black) - $60 each
Rear SKYLINE garnish (black) - $50
Rear bumper (black) $80
Rear reo bar - $80
A/C condenser - $150
Front reo bar - 2 small areas cut out for FMIC - $100
post-35556-1226835868_thumb.jpg post-35556-1226836384_thumb.jpg post-35556-1226836418_thumb.jpg
R33 alternator - $80
Fuse box lid - $20
Battery, good charge - $50
Stock cat - $50
HKS super dragger catback exhaust - $250
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel - $80
Stock SMIC & piping - $80
Rear suspension - pedders lowered springs & stock shocks - $100
Front lower control arm, drivers side - $70
Front upper control arms (spare from another car, undamaged) - $80 pair
Front hubs - $70 ea
Rear lower control arms - $60 ea
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Non-abs Viscous LSD diff - $150
Driveshafts $60 pair
Rear upper arms - $50
Front calipers - $250 pair
rear calipers - $150 pair
Rear rotors - $50
Drivers door window switch - $80
Drivers window switch surround - $40
Drivers door motor - $80
Drivers door trim - $50
Passenger door motor - $50
Dash surround (goes around CD player, cluster, etc) $80
Instrument cluster, 121,000ks - $120
Gear stick surround, with boost gauge built in - $60
Under dash piece (covers fuse box) $30
Genuine nissan floor mats, full set - 100
S2 Steering wheel minus airbag, good nick - $60
Front seats, immaculate condition - $200
Rear seats, immaculate - $50
Seatbelts, full set - $60 (will seperate)
Ignition barrel + door barrels + key - $100
interested in a couple of the parts also im located in vic can pay for the postage Apexi power intake filter Front strut brace - Chrome/aluminium/silver door sills pair - Charcoal canister - - Drivers door window switch - Gear stick surround, with boost gauge built in - Rear seats willing to pay 250
  • 2 months later...
  • 3 months later...
R33 S2 motor:
Rear reo bar - $80
Fuse box lid - $20
Stock cat - $50
Washer bottle - $20
Front hubs - $70 ea
Rear rotors - $50
Hi, I want to buy the bolt on spaces, do u have a contact. I am in Sydney
sorry guys
THIS THREAD IS FROM 2008! EVERYTHING IS SOLD!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
