  • Replies 75
  • 5 months later...
Hey mate do you have the plastic bit that fits under the car stereo ? (Skyline R33) http://www.skylinesaustralia.com/forums/po...26-IMGP0142.JPG (example) put the keys and stuff in it... im in Melbourne if you have it might need to post it out or something.
Hello how are you?
First what area you in?
Second i need best price for me to pick up al parts you have out of my list below, this is what i need:
Front bar, headlights, bonnet lock support, bonnet lock, bonnet, grill, radiator, radiator support, rear bar, rear bar irons, both tail lights, boot lid (no spoiler), boot lid lock, fan clutch, ac condensor... think that's all for now. thanks >_<
Dannie
Hey guys, Ive got a r33 gts-t for wrecking here in sydney. It's hit a gutter on the front left wheel so the left LCA, left guard, left headlight and bumper are gone, but pretty much everything else is still here
If you're after any little bits or pieces send me a PM. Pics below
R33 S2 motor:
Approx 121,000 ks, good compression. Comes with turbo, coilpacks, alternator & ECU (p/s and a/c are sold, loom sold/in use) $1600
5sp manual conversion to suit R33/ R34:
Gearbox has around 121,000ks, good condition. Everything ya need.. includes clutch, flywheel, box, tailshaft, master cylinder, slave cylinder + lines, shifter, pedals and gear surround - $1750 negotiable
or Box, slave cyl, tailshaft $1400
R32/R33 Boss kit - $40
GFB boost T controller - $20
Apexi power intake filter - $40
Apexi turbo timer - $80 Works well, plugs right into the r33 ign loom. Should fit R32/R34 as well
HKS fuel cut defender - $50 posted
Chrome/aluminium/silver/whatever door sills - $120 pair
Front & rear strut braces - $150
Pioneer 3-way 6" speakers - 220watt / 60wrms - $60
post-35556-1226836282_thumb.jpg post-35556-1226836209_thumb.jpg post-35556-1226836251_thumb.jpg
Set of R33 gts-t stockies with tyres. Tyres have some tread but the rubber seems a bit shagged - $200
5 stud space saver - $50
5 stud bolt on spacers, 5x114.3 to 5x100. one pair 14mm, the other 20mm
Drivers side sideskirt & rear pod - $80
R33 GTR spoiler + bootlid (lock not included) - $350, pickup only!
S2 drivers side headlight - $200
S2 bonnet (black) - $300
S2 front grille (black) - $60
Side mirrors (black) - $50 each
Tail lights (black) - $60 each
Rear SKYLINE garnish (black) - $50
Rear bumper (black) $80
Rear reo bar - $80
A/C condenser - $150
Front reo bar - 2 small areas cut out for FMIC - $100
post-35556-1226835868_thumb.jpg post-35556-1226836384_thumb.jpg post-35556-1226836418_thumb.jpg
R33 alternator - $80
Fuse box lid - $20
Battery, good charge - $50
Stock cat - $50
HKS super dragger catback exhaust - $250
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel - $80
Stock SMIC & piping - $80
Rear suspension - pedders lowered springs & stock shocks - $100
Front lower control arm, drivers side - $70
Front upper control arms (spare from another car, undamaged) - $80 pair
Front hubs - $70 ea
Rear lower control arms - $60 ea
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Non-abs Viscous LSD diff - $150
Driveshafts $60 pair
Rear upper arms - $50
Front calipers - $250 pair
rear calipers - $150 pair
Rear rotors - $50
Drivers door window switch - $80
Drivers window switch surround - $40
Drivers door motor - $80
Drivers door trim - $50
Passenger door motor - $50
Dash surround (goes around CD player, cluster, etc) $80
Instrument cluster, 121,000ks - $120
Gear stick surround, with boost gauge built in - $60
Under dash piece (covers fuse box) $30
Genuine nissan floor mats, full set - 100
S2 Steering wheel minus airbag, good nick - $60
Front seats, immaculate condition - $200
Rear seats, immaculate - $50
Seatbelts, full set - $60 (will seperate)
Ignition barrel + door barrels + key - $100
interested in a couple of the parts also im located in vic can pay for the postage Apexi power intake filter Front strut brace - Chrome/aluminium/silver door sills pair - Charcoal canister - - Drivers door window switch - Gear stick surround, with boost gauge built in - Rear seats willing to pay 250
  • 2 months later...
  • 3 months later...
R33 S2 motor:
Rear reo bar - $80
Fuse box lid - $20
Stock cat - $50
Washer bottle - $20
Front hubs - $70 ea
Rear rotors - $50
Hi, I want to buy the bolt on spaces, do u have a contact. I am in Sydney
sorry guys
THIS THREAD IS FROM 2008! EVERYTHING IS SOLD!
    • I also think it comes down to the dollars spent for quality items, there's some cheapie versions out there, which look fine, but, there are versions of much higher quality out there, but, you obviously pay more for the quality of materials used and quality control When I first got work done by Advan Performance on my old R33 the silicone joiners were cheapies and actually blew out on a joiner heading to the plenum, when I then took it to Unigroup they said that the silicone hoses they used and were junk, Unigroup replaced every hose on the engine with much higher quality items and from then I never had a issue with any hose Additional cost and quality gets you quality silicone base materials and quality reinforcement fabric stuff As for OEM rubber hoses, again, quality materials and strict quality control will give you quality hoses, but only to OEM spec, I believe using quality silicone replacements is a upgrade I  saying this I have only dealt with vehicles I own and play with
    • Not gonna lie my sense of smell isn't the best. But it does look more grey to me. It doesn't smell like oil, friend says it smells like fuel.
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
