(I did a search and could'nt find anything, maybe the actual topics if any are just abbreviated funny)
I've got a '92 import HCR32, with next to no modifications except for an aftermarket BOV of somekind, and an HKS Super Dragon Exhaust with a custom exhaust manifold. Its running rich, like 14.5Litre p/100km rich, from what i've read i should be doing mid 10s even 11s p/100km;
So i've decided to service all of the basics,
Oil Filter, Fuel Filter, Oxygen Sensor, Vacuum hoses, cleaning the MAF intake sensor(A bit sticky when cold), cleaning the pod and intercooler, Rocker Cover Gasket (a bit leaky), and some of the oil pump pressure lines etc. Spark Plugs, Engine/Diff/Gearbox Oil Change, Fuel Pump(mines just about had it), and attempting to find some decent coilpacks that are'nt half a wopper, and since Bosch dont make RB20DET ones, I dont know what to get.
:DGetting to the point, its armed with this BOV, which sounds awful ricey and i cant for life of me think how its a good thing to have. it appears to vent directly to atmosphere, which in my understanding is'nt a good thing because then the exhaust side oxygen sensor tis'nt picking up correc readings (Fuel/Air Ratio's and will in turn run the car over-rich?).
so would i not be better of returnng the system back to its original Stock Plum-Back BOV? or is there a system out there that will work even better than the stock setup thats not too expensive and silences the Air Bypass.
https://www.sau.com.au/forums/topic/245115-stock-bov-aftermarket-rb20det/
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
