hey
I currently own an R34 and i have backfiring issues. I just wanted ask how to fix this problem. Is it really a major issue and whats the consequences of not fixin this problem? Also what causes this backfiring problem.
The car is currently runing stock boost and stock everything. I just added an air filter and a bov.
Thanx ppl :)
https://www.sau.com.au/forums/topic/24513-back-fire-issues/
I think maybe u missing the cat and running too rich mate!!
But that's good, my car have a 1/2m dia. fire ball when dyno
If you want to stop the backfire, buy a SAFC or have ur ECU chiped. it can allows u to set the fuel and air ratio. U can come to BMT and ask for DR. Drift in Melbourne
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523182
hey thx ppl for the advice...
I'm waiting for the SAFC ... hey r32impul.. how much is it to get a chipped ECU from BMT ? i just want to know the price. I think i should go get the car checked out from a professional just in case. Dont wanna do shit myself since i know shit about car.
Friend said that if i dont get the backfiring sound outta the way, it mite blow my cat convertor and its gonna waste more money then fixing it now.
LoL sorry this is a stoopid question, what does rich and lean mean when its about engines? To fix that u need a SAFC ?
=] thx ppl
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523204
Rich means more fuel in your fuel air mix, lean means less. The SAFC will allow you to tune your mix thus stopping the back fire.
The stock computer calculates air using your air flow meter, and assumes the air will still be around when your throttle body closes. Hence it puts more fuel into the mix.
(well put simply.. if anyone was to elaborate be my guest)
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523216
hey guys - sorry but i am worse than charlie34.
So the backfire is caused by the car running rich (can it be cos of the 3" dump back i got and no electronic supports??) and that is causing the detonation of unburnt fuel in the exhaust? So any sort of management that will alter the air/fuel ratios to let it run more lean should eliminate this right?
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-528918
=] thx ppl
PM me for discussion on your options for a R34. Had another 34 GTT in the other day that was detonating severly as someone had moved the CAS.... looks like a checkup on the dyno has aved him a motor....
Doc.
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-531587
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
