hey
I currently own an R34 and i have backfiring issues. I just wanted ask how to fix this problem. Is it really a major issue and whats the consequences of not fixin this problem? Also what causes this backfiring problem.
The car is currently runing stock boost and stock everything. I just added an air filter and a bov.
Thanx ppl :)
https://www.sau.com.au/forums/topic/24513-back-fire-issues/
I think maybe u missing the cat and running too rich mate!!
But that's good, my car have a 1/2m dia. fire ball when dyno
If you want to stop the backfire, buy a SAFC or have ur ECU chiped. it can allows u to set the fuel and air ratio. U can come to BMT and ask for DR. Drift in Melbourne
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523182
hey thx ppl for the advice...
I'm waiting for the SAFC ... hey r32impul.. how much is it to get a chipped ECU from BMT ? i just want to know the price. I think i should go get the car checked out from a professional just in case. Dont wanna do shit myself since i know shit about car.
Friend said that if i dont get the backfiring sound outta the way, it mite blow my cat convertor and its gonna waste more money then fixing it now.
LoL sorry this is a stoopid question, what does rich and lean mean when its about engines? To fix that u need a SAFC ?
=] thx ppl
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523204
Rich means more fuel in your fuel air mix, lean means less. The SAFC will allow you to tune your mix thus stopping the back fire.
The stock computer calculates air using your air flow meter, and assumes the air will still be around when your throttle body closes. Hence it puts more fuel into the mix.
(well put simply.. if anyone was to elaborate be my guest)
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-523216
hey guys - sorry but i am worse than charlie34.
So the backfire is caused by the car running rich (can it be cos of the 3" dump back i got and no electronic supports??) and that is causing the detonation of unburnt fuel in the exhaust? So any sort of management that will alter the air/fuel ratios to let it run more lean should eliminate this right?
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-528918
=] thx ppl
PM me for discussion on your options for a R34. Had another 34 GTT in the other day that was detonating severly as someone had moved the CAS.... looks like a checkup on the dyno has aved him a motor....
Doc.
https://www.sau.com.au/forums/topic/24513-back-fire-issues/#findComment-531587
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
