Due to a change of plans in my build up I have these for sale:
1. Greddy Emanage Blue + Ignition, main, and Rb25det Neo adaptor
This is the full kit with everything you need to get going. Never fitted, in orginal box.
$350 + post
2. Apexi Hybrid "cross back" FMIC.
This is a genuine Apexi cooler in excellent condition. Comes with brand new piping and silicon joiners and high grade clamps. Uses exisiting piping which means no cutting holes!
$450 + post
Located in Kogarah, Sydney
PM or call 0416275449
Pics on their way.
Also driver AND passenger Bride Superlow seat rails for R33 GTST coupe (could fit others)
$150 each + post (available this weekend)
From the Apexi site:
The Hybrid GT Intercooler Series uses an exclusive cross flow design on all the cores. These cores are the only cores designed specifically for front mounting. The front of the core uses a delta fin type-face with two different types of fins. The fins at the base of the Delta Wedge are tightly packed while the fins at the top of the Delta Wedge are loosely packed. This allows the channelled air flow at the base of the Delta Wedge to cool more air while the loosely packed fins at the on the top prevent any unnecessary wind turbulence.
The front mount is for any skyline I believe. It was off a R33 orginally but I never fitted it to my R34.
The emanage harness is the universal one. There was a bit of confusion here people. The Neo engine requires and aditional harness on top of the Ignition and Main harness it comes with. So in total there are 3 harnesses it comes with. Sorry about that.
Also
Pillar gauge mount to suit r33 I believe but should fit other skylines (did fit a R32 with a bit of a gap) = $30 posted!
Koni shock adjuster + instructions = $5 posted!!!!!!
Pics
Gauge holder and Emanage R34 Signal adaptor still available. Rest has been sold.
Selling signal adaptor for $20 with free post!
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
