On the weekend i dyno'd my car at the Brisbane Autosalon. I Made 260rwkw. Now i had been told it was dyno'd on 8cylinder Shoot mode. Would this make a difference to the power figure reading?? Apparently it can read up to 80rwhp less. Is this true??
A vehicle that i know that made 340rwhp a couple of days before the salon made only 200rwkw on the dyno at the show. So there was something definately wrong.
Thanks
Harun
https://www.sau.com.au/forums/topic/24515-dyno-reading-question/
Hi RNS11Z, there are different inertia loads from engines of different configuration. In Shootout mode the dyno automatically selects the appropriate inertia loading. Basically it has a look up table for a 4 cylinder, a 6 cylinder and a V8. If the you run a 6 cylinder on the dyno with a V8 inertia loading it will allow for more inertia than the engine actually has. So it will read slightly higher output than it would in a 6 cylinder inertia loading had been used.
Logically there are great differences in inertia loading from a 6 cylinder dinosaur engine (say a V6 Commondoor) and a DOHC straight 6 (like an RB). So I wouldn't worry too much as the 6 cylinder inertia loading may have been just as inaccurate as the V8 one.
Hope that helps
A/S dyno's
lol... i made 190rwkw @ 6600rpm on 10psi boost at my usual dyno place and it reads low-ish
at auto salon... on 10psi i had made 210rwkw at 5000rpm (i dont make any decent power till 4500rpm as i got a t04e)
Pity the car was pinging a little and they stopped.
It could've gone to around 240rwkw i reckon as the graph just kept going
just goes to show how different dyno readings can vary really
True true. Yours read higher then expected. The guy with s15 i know (which had made 340rwhp - 250rwkw a couple of days before it only made 200rwkw). So who knows what was going on. Im just trying to find out wether my results were correct or not. Doesnt really matter as im going back on the dyno very soon
While shootout mode may help with more consistent readings, I understood you cannot compare wheel power figures between 2 different dynos, there are a host of differences in setup between them.
The power figures are only really comparable for the same dyno on the same day.
that is 100%... spot on the money.
IF you wanna compare results you gotta go the the same dyno on the same day.
Otherwise all sorts of variable come into it.
Aahh... if you wanna see, just get a few mates together for a dyno day :)
I agree that weather conditions can effect horsepower esp. in turbo cars and therefore give slight hp variance but if you look at the theory of a dyno it shouldnt make any differance what motor is pushing the wheels against the retarder when youre talking hp its hp ,and shootout mode sounds like a wanker term, youve either got it or you dont because hp is hp .One hp in a 1500hp drag car has the same power hp as one hp in a 30 hp zeta.
As far as I know, a dyno measures torque not power, and even then it is at the wheels, not the flywheel. The rwkw are then calculated based on the revs (if the operator actually calibrated them too).
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
