Not sure if it helps Dane-O, but I just found these 4 places in the yellow pages.
Might be worth a call to each to see if they could do it.
Flock Finishers Pty Ltd
12 Swift Way Dandenong VIC 3175 - get directions
ph: (03) 9706 6678
Concept Coatings
11 Elliott Rd Dandenong VIC 3175 - map
ph: (03) 9794 6916
International Flock Coatings Pty Ltd
21 Lathams Rd Carrum Downs VIC 3201 - map
ph: (03) 9775 0050
R & L Commercial Flocking
Unit 3, 71 Brunel Rd Seaford VIC 3198 - map
ph: 0405 823 789
https://www.sau.com.au/forums/topic/245193-dash-flocking/#findComment-4266082
Thanks a lot for that guys and gals!
Concept coatings no longer exist, but Flock finishers do it, so I'll pop down there.
Cheers
hey mate i have been thinking about doing the same thing to my gtr the glare off the dash is rediculous. can you please keep us all posted on how it goes how good it works and how easy it is to scratch off and that sort of thing? cheers mate
Dion
https://www.sau.com.au/forums/topic/245193-dash-flocking/#findComment-4270292
is this different to getting the dash covered in suede/alcantara?
how much would flocking the dash cost?
Similar, but it's not a mat of material, it's like small suede particles. Not sure what the cost is yet, I'll find out tomorrow and let you know.
https://www.sau.com.au/forums/topic/245193-dash-flocking/#findComment-4272469
should cost u no more the 15-20 per panel,
if your a smoker its not recommended to smoke in the car for a couple of weeks. as basically the whole idea of flocking is that they use glue and electrostatic to bind the suade like particles onto what ever panel you want done. ..
u can ask then do flock it a lil thicker cos if they only do 1 layer it will wear very quickly. for a good effect and longevity, 2 layers. BUT if its to thick you will need to trim some of the flocking of when u stick the panel back on to make it stick
https://www.sau.com.au/forums/topic/245193-dash-flocking/#findComment-4273262
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
