hey guys.. just a quick question
im getting my car dyno tuned and a vipec installed on friday, and getting the boost control set to 10 and 16psi.
car is a
96 s2 rb25det
kkr 430 turbo
fmic
just wondering if im gonna run out of fuel when shes all tuned up and running schmick, a mate has said i might with the power il be running
thanks!
https://www.sau.com.au/forums/topic/245203-will-i-need-injectors-fuel-pump/
car is a
96 s2 rb25det
kkr 430 turbo
fmic
thanks!
don’t expect much power from the kk430, i'd look out for boost issues if your running a internal wastegate?
you will need a new fuel pump eg: 040 or walbro, injectors will run very close to max and your AFM will max out if your going to run 16psi
i suggest:
bosh 040 or walbro
bigger injectors
z32 AFM
keep us updated, keen to see the end result
here is a recent build that i just finished for a friend of mine, might give you some good info.
http://www.skylinesaustralia.com/forums/Mo...st-t239039.html
cheers!
yeh mate internal wastegate at the moment, iv been well informed about the boost issues. read your thread too.
at the moment going off my boost guage it doesnt go past 12psi, reckon that will be a problem? mate said he has seen them creep to 18psi :S
also with the ecu im getting (vipec) it doesn't use an AFM, its map sensored or whatever its called (don't really know much at all about this - anyone who is bored feel free to explain it to me, i need to do alot of reading over the next few days !).
So you think il need a new fuel pump definitely, il see how it goes on the dyno and post results etc over the weekend!\
oh by the way all the work is being done at godzilla motorsport
i'd be very surprised if you don’t get boost creep, they all do it and just unavoidable.
with the supporting mods, your fuel pump may or may not be enough you just don’t know in what condition it's in. this also comes down to reliability, why would you want to risk your car leaning out and causing serious damage to your engine which will result in a rebuild.
same goes for your injectors, you will be running them on max and it’s just not safe and will limit the amount of boost you can run.
if your going with the MAP sensor option there is no need for a AFM so no need to worry about that then.
i suggest you go with a bigger pump and injectors to ensure you have enough fuel to keep it safe and to achieve the desired result.
:ph34r:
i'm in the same boat but i have a power fc and kkr480, i was looking at injector and pump for it.
Can you change it to be externally wastegated??
pretty sure you can weld it up so that it requires an external, dont ask me how though lol.
just been looking at turbos to buy and saw a couple that had been made into external.
Ps good luck with the build up existence, definatley replace the pump atleast (old and worn out) mine is about to crap itself and im only running bit above stock power.
be best to keep an eye on the fueling side as well so get yourself a decent fuel pump and injectors.
my 34 has the mods listed below in my sig my im maxing out my stock injectros and it pings at high boost so upgrading them next week to 480cc. better to be safe then sorry mate.
save up a little more dosh and get it done properly. get yourself a highflow fuel pump and decent injectors. fuel pumps are not that pricey its the injectors that are the killer, but its better to have everything and take it and et it all tuned at once as you will be saving on getting the injectors tuned again.
if your interested in injectros check out power flow injections here in melbourne. they quoted me $840 for 480cc injectors for my 34 http://www.powerflowinjection.com/ and so far they have been the cheapest.
so ye get you pump and injectors first before you try and tune it for high boost or you will end up spending more money on a rebuild.
or if you really really really wanna get it put on asap put it all in but tune it to a safe boost so around 200rwkw till you can afford to upgrade the injectors and pump
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
