hi guys
i recall the R33 GTS-t has an auto-locking system for the doors when the car exceed 40km/h
im not sure abought r33 GT-R......
what about the r34 GT-R? does it come standard?
gee guys im suprised no one has an answer for this thread
doesnt ANYONE here own an R34 GT-R????
hi guys
LOL!
You do own a R34 GTR right..? You could have just tested it yourself :P
I know I have to lock the doors myself in my R32.
My 34GT autolocks as soon as you start the car, not sure if its a stock feature though.
Just out of curiousity does anyone know if there was any r34 that came factory with no keyless entry?
keyless entry or no keyless entry?
you mean a magic fob where you stand near the door with it in your pocket and it unlocks for you?
No i ment did any r34 come factory without keyless entry. Keyless entry as in you press the button and the car unlocks.
Nissan reakons mine didnt. And that i dont have a immobiliser. But they were only going but what there computeres said
That is a confusing question. but most R34 GTRs do not have factory keyless entry. there was a dealer option remote central locking that comes with a nice little remote with GTR emobossed on the back. there was also an immobiliser option that has a proximity immobiliser reader in the key barrel with the immobilisers mounted in the key themselves.
Yes sorry i was having trouble wording it. So is that the same with GTT's and GT's?
I only ask because my remote isnt stock, and im having problems figuring out if my central locking is aftermarket or not
Edited by Darkplague
Okay I don't know if this helps in any way, or if it'll confuse people even more.
But my 1999 R34 GT-R V-spec comes with remote locking/unlocking, keyless entry, whatever you want to call it. As mentioned it comes with a FOB with a GTR logo on the back of it.
My car does not auto lock when I start the car or drive.
My best mate has a 1998 R34 GT-T and his comes with a FOB too for central locking AND his car auto locks the doors the moment he starts his engine.
Is there a way of enabling the auto-lock feature?
Yeah thats what my 1999 r34 GT does to, autolocks soon as the engine starts.
Accept i wanna know if theres a way of disabling it.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
