  • Replies 126
Posted Images
agreed, stags are porno.
seems its hard to find a grade 4 auto in black though.
your not looking hard enough :banana:
>>Black 260RS 25k<<
>>Black 2.5x<<
>>Black 1999<<
>>Black RS4<<
>>Black RS4<<
how about white 260RS
>>White<<
teach her to drive manual in the getz :D and say your not driving the new car until you don't crunch gears :)
pfft, you gotta be joking right?
she laks the co-ordination the be able to drive manual...
i tried teaching her in the getz a while ago,
after about 3 fat skids, 6 bunny hops and 3 years of clutch life gone, she gave up. thank god!
automagic will do, its only gonna be a family car.
you've changed man, you used to be cool
hehe..im only kidding...Appropriate choice for an up and coming 'family man'
Ben taught me how to drive manual in a suzuki ignis... then i upgraded slightly to a r32-GTR LOL.
Where bouts do you live craig? if you wanna come up to show your missus the stag maybe we'll do a bbq or something.
Jeez you could've picked a better looking one than that to try and convince people, that thing looks like arse :D
*edit* after having a decent look, the car itself isn't too bad, but the cheap looking Bob Jane-spec rims and off road profile tyres just ruin it completely. 0/5 would not watch again.
Edited by AndrewJZX100
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
