The GT-R had finally broken the 10 second barrier! Congratulation to d3gtr from the nagtroc forums - Amazing! Well done :(
d3gtr:
Just to let everybody know the Jotech D3GTR ran the fastest recorded time (that I know of) at the Texas Motorplex in Ennis, TX. The ¼ mile time recorded was 10.956 seconds (first GTR to break 11 seconds!!!). Oh and get this it was done on 22 inch wheels, three piece wheels. This was done directly after the Hot Import Showdown held at this track – which was an absolutely incredible event that I will not miss in the future. Cliff you did a great job!
I am extremely excited of the performance of this car and give a great thanks to Kenny Tran and the guys Jotech Motorsports in Garland, Texas, for the absolutely incredible job they did with the modifications, dedication, follow up and just damn good work they did with my car. Kenny and I spoke many times over the weekend by phone and he gave me different instructions and opinions on how to get the best time. What’s the chances Kenny would know how to run a quarter…LOL.
I am on my way home from the track and will arrive at in about 3 hours. I will either post video and time slip tonight or tomorrow.
I Freaking Love This Car!!!!!
D3
Running an HKS GT570 kit, Mine’s Exhaust, and the COBB Tuning AccessPORT. It’s making 548 hp and 573 lb/ft of torque.
http://www.youtube.com/watch?v=Y4Tfjz0U3C4
https://www.sau.com.au/forums/topic/245222-1st-gt-r-in-the-10s/
the owner/driver has commented and says "the transmission is fine"
I suspect someone either trying to be funny, or a jeleous Porsche driver trying to put shit on a better car (maybe the person he was racing lol).
B.
Anyone notice the comment posted about the video?
Apparently the transmission is gone now in that car.
i noticed that when i saw it this morning, but realised the comment about the transmission was made by another account to the person that posted the video....
AnimalHouseRacing 10.88 @133.50 " NO LAUNCH CONTROL"
I would like to announce that the Animal House Racing GTR went 10.88 @133.50 today.
I would like to thank everyone at Cobb tuning for there custom program. Thank you JOHN
We are still running the same map as all the other passes, running a steady 17psi.
We did not use launch control at all.
The setup for the GTR is as fallows:
AHR CERAMIC WHEEL BEARINGS
AHR CERAMIC PULLEY BEARINGS
AHR THERMAL GASKET SET
AHR RACE Y PIPE
COBB ACCESS PORT
93 PUMP GAS w/1 gallon 100 oct
We believe the car has more in her but the track is closed for the season.
Thank you all at Nagtroc for the support
Stay tuned for next year with our AHR Godzilla turbo kit
Slip
60' 1.858
330 4.768
1/8 7.137
MPH 106.08
1/4 10.88
MPH 133.50
http://videos.streetfire.net/video/Animal-...1088_201390.htm
http://www.nagtroc.org/forums/index.php?showtopic=26624
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
