Hi all,
I'll call up a mechanic tommorow but just wondering what kind of ballpark figure am i looking at to fix the power steering rack boot.
Its the rubber corrugated thingo and its split right down the middle leaking all my power steering fluid.
(isit hard to fix yourself?)
https://www.sau.com.au/forums/topic/245226-power-steering-rack-boot-oil-leak/
well if its leaking powersteering fluid, then you have a bigger issue than just the boot.
seals in the rack are probably worn, i have the same issue but havent had time to fix it up.
leak has reduced after going through about 2 bottles of power steering fluid that has a leak stopper in it. its not gone, but its a huge amount better.
yikes.. that's not good..
yeh i've just been refilling mine as well takes about 2 weeks till i get the hicas light again..
what leak stopper are u using?
does that mean i have to replace the whole rack? or can you just replace the seals?
alright just for whoever's info..
called up mechanic, quoted worst case need to reco the steering rack,
at around $200 to reco it (if necessary)
and at max around $240 to remove it
um.. just or anyone's info it ended up costing ~850 all up ..
$400 for the full rack reco, and then 250 for tie ends and 200 for labour..
and another 80 for a wheel alignment..
siiigh
  • 3 weeks later...
ouch, didnt think it would be that much, hows the steering feel now?
feels really tight.. as in no play at all. BUT
that said i hardly had much play in the steering before hand anyway..
so while its tighter.. its not ~$850 tighter.. i think i woulda been happier going through a couple of bottles of steering fluid.
but ANYWAY.. at least its fixed and i dont have to worry about it for another 100 000kms
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
