Hey guys n Chicks, Most Of you no my car, R33 s1, Anywhos, Whats the dealyoyo withthe hicas light coming on all the time? Only comes on when im doing between 80kms to 110kms - usualy on the FWY or on my way home on great northan hwy?? SHould i be freaking out?
Kels
https://www.sau.com.au/forums/topic/245284-why-is-my-hicas-light-turning-on/
Mine did it a couple of times, apparently its nothing to be worried about. Happened to my dad a few times driving up and down the freeway on the way to work. However, I've been to your place a number of times now and my light hasnt come on in months.
hi im new here is your wheel-alignment straight? cuz ma cars wheel alignment was out b4 with da steering wheel off-centre n ma hicas light came on(happened on da freeway as well) n when i put it on da nissan consult tester it says no neutral signal at watever degrees n after i had ma wheel-alignment done it never came on
Edited by R33_NICK
hey sniper ( think you live round the corner from me ) . hicas light comes on to indicate that the hicas system has a fault and has been deactivated . on the r32 model i believe this could only happen after a certain distance of driving and above a certain speed . once the system is deactivated it stays as such until the motor is switched off .
so you have a fault . just rip it out , hicas is gay anyway
kermit 0422549050
Kels
faulty steering wheel position sensor , steering wheel not centered correctly or no speed sensor input if you have an aftermarket steering wheel without a hicas compatible boss kit
it happens on the fwy because you have not moved your steering wheel in a while and there has been no steering input for the pre-determined amount of time to trigger the hicas error
very common search for more info if you need it
just avoid the freeway or great northern highway and you'll be fine.
but in all seriousness this issue is regular and has been covered before. the forums are full of great information. it's there if you look for it :)
Chances are its the aftermarket steering wheel problem, exact same thing happens to my 32 i just ignore it.
Failing that 100 dollars for a lock bar and you can sort the problem out.
+1 for the aftermarket steering wheel causing the issues.
if you use the search feature you might find there's another thread on the forums on hicas issues.
Mmmm locker bar * thinks * hahaha that could be fun??? Yeah my wheel alignment was done like a month ago, its all straight, BUTTTTTT my steering wheel isnt, well after the alignment that is... Ino that i get a bit of humming in the rear end, but i presumed it was just my diff getting old... And yeah the light switches off when i turn the car off... Ino some times when i slow down like betweenn 20 - 40kms my steering gets really stiff and like impossible to turn, then go's away.... and i thawt that was hicas having a sad.... Thanks for your help guys, i now half understand hicas, i was starting to get a bit concernd haha!
Kermit - Lol No i dont live around the corner from you, i was at my mates :blink: I waved hahaha!!!
hmm power steering fluid.... that might explain the stiffness when you slow down if the hicas light is on, right? Going to Tenagah this friday, I'll get them to have a sqizz and tell me the issue cos Kelly you described the EXACT same problems I'm having!!
i read that thread Benson!! And I got confused as hell! I read the 'to hicas or not to hicas' thread and i was liek whaaaa
I've been best advised to just leave it in and stop crying about it lol
When r you going to Tenagah for the HICAS, Bens?
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
