Hey guys n Chicks, Most Of you no my car, R33 s1, Anywhos, Whats the dealyoyo withthe hicas light coming on all the time? Only comes on when im doing between 80kms to 110kms - usualy on the FWY or on my way home on great northan hwy?? SHould i be freaking out?
Kels
https://www.sau.com.au/forums/topic/245284-why-is-my-hicas-light-turning-on/
Mine did it a couple of times, apparently its nothing to be worried about. Happened to my dad a few times driving up and down the freeway on the way to work. However, I've been to your place a number of times now and my light hasnt come on in months.
hi im new here is your wheel-alignment straight? cuz ma cars wheel alignment was out b4 with da steering wheel off-centre n ma hicas light came on(happened on da freeway as well) n when i put it on da nissan consult tester it says no neutral signal at watever degrees n after i had ma wheel-alignment done it never came on
Edited by R33_NICK
hey sniper ( think you live round the corner from me ) . hicas light comes on to indicate that the hicas system has a fault and has been deactivated . on the r32 model i believe this could only happen after a certain distance of driving and above a certain speed . once the system is deactivated it stays as such until the motor is switched off .
so you have a fault . just rip it out , hicas is gay anyway
kermit 0422549050
Kels
faulty steering wheel position sensor , steering wheel not centered correctly or no speed sensor input if you have an aftermarket steering wheel without a hicas compatible boss kit
it happens on the fwy because you have not moved your steering wheel in a while and there has been no steering input for the pre-determined amount of time to trigger the hicas error
very common search for more info if you need it
just avoid the freeway or great northern highway and you'll be fine.
but in all seriousness this issue is regular and has been covered before. the forums are full of great information. it's there if you look for it :)
Chances are its the aftermarket steering wheel problem, exact same thing happens to my 32 i just ignore it.
Failing that 100 dollars for a lock bar and you can sort the problem out.
+1 for the aftermarket steering wheel causing the issues.
if you use the search feature you might find there's another thread on the forums on hicas issues.
Mmmm locker bar * thinks * hahaha that could be fun??? Yeah my wheel alignment was done like a month ago, its all straight, BUTTTTTT my steering wheel isnt, well after the alignment that is... Ino that i get a bit of humming in the rear end, but i presumed it was just my diff getting old... And yeah the light switches off when i turn the car off... Ino some times when i slow down like betweenn 20 - 40kms my steering gets really stiff and like impossible to turn, then go's away.... and i thawt that was hicas having a sad.... Thanks for your help guys, i now half understand hicas, i was starting to get a bit concernd haha!
Kermit - Lol No i dont live around the corner from you, i was at my mates :blink: I waved hahaha!!!
hmm power steering fluid.... that might explain the stiffness when you slow down if the hicas light is on, right? Going to Tenagah this friday, I'll get them to have a sqizz and tell me the issue cos Kelly you described the EXACT same problems I'm having!!
i read that thread Benson!! And I got confused as hell! I read the 'to hicas or not to hicas' thread and i was liek whaaaa
I've been best advised to just leave it in and stop crying about it lol
When r you going to Tenagah for the HICAS, Bens?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
