I always thought the s2 was marginally heavier in stock form, airbags, big-assed frontbar ect.
The didn't seem to lose any weight elsewhere and you have to agree there's a fair bit of extra
gear bolted onto a s2 compared to a non body kitted s1.
Could be a small.. yet fat childs difference in weight.
Maybe
https://www.sau.com.au/forums/topic/245289-s1-vs-s2/page/2/#findComment-4270876
  • 4 weeks later...
They are all speed limited to 180km/h, regardless what skyline it is. (probably the only one that isn't is the australian delivered R32 GTR).
EDIT: i just re-read your post and realised you weren't asking a question, so yeah your right.
Edited by PM-R33
https://www.sau.com.au/forums/topic/245289-s1-vs-s2/page/2/#findComment-4323311
  • 1 year later...
I've been in a couple of rb25s with speed signal wire cut. And they all behave strangely. The power is not the same. They don't have rev cut while driving. And they rev past 7k and make very frightening sound. Not the lovely revlimter-bounce.
Hook up the speed signal.
https://www.sau.com.au/forums/topic/245289-s1-vs-s2/page/2/#findComment-5061297
Your imagining things or there is something totally unrelated to the speed limiter cut wire going on. Or your freinds have cut the "speed signal" wire and not the "speed limiter" wire. The speed limiter wire will not effect the way the car drives what so ever.
https://www.sau.com.au/forums/topic/245289-s1-vs-s2/page/2/#findComment-5061598
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
