Just come across a set at the right money, what do you think of them ??
Would they suit my set up??
Power FC
Dual 3" > 3.5"
Sub Zero manifolds and dump pipes
260' in and ex cams (Tomei)
cam gears (Tomei)
4" Trust cooler
700cc Sard Injectors
600hp Fuel pump
HKS Twin plate clutch
any help on the turbo's would be great..
P.S. This car is not being built as a Drag car, just a quick streeter
https://www.sau.com.au/forums/topic/24530-hks-gt-ss-turbos-what-do-you-think/
If you are after 600hp you should buy a T51R SPL. Nice and streetable with the ability to get up to 650hp with more boost. A 5 inch exhaust would make it spool really quick, like 2 bar at 2,000rpm. Perfect for third gear burnouts with the standard CA18 gearbox. Need a single plate copper clutch though, so it hooks up mad. If you get a carbon bonnet you will go faster too cause it's 50kg lighter than a GT-R bonnet.
My friend's holden ute has 600hp with big chrome rims and he's making 600hp with the standard turbos but with a GCG 700hp Hi-flow cause you make the horsepower that their numbers say you will.
I think the GT-SS and GT-RS are too new to be a common turbo conversion in Aus. Plenty of 2530's + 40's.... Merli was doing a bit of research about the new ones, he might be the one to ask.
As far as web-board comments and opinions, the UK GT-R board has a couple of people that have tried both... and swear by the GT-SS. They claim the GT-RS is too big and meant for a stroked engine..
hey 600 is this a rb25 or an rb26?
I just clicked b4 I chastised inasnt's post and he is right
the ss are 320-350 hp rated the rs I not to sure but say 400 450.
If your on a rb 25 gt 3040 or bigger is required on an rb 26 the ss would be adequete but you would need to run high boost to make the big power. but that is no problem provided the car is tuned well ie no detonation.
cheers
meggala
a t51 kai would be nice on either motor spl being a bit to big for what you want
Straight from the HKS website:
GT-SS (low mount, bolt on)
GT-RS (low mount, bolt on)
GT2835 (Full Special Kit)
A comparison:
That last comparison has changed since i last saw it on their website. The old pic was easier to read and showed what order each individual turbo had as far as supporting power, response, etc. Obviously all of HKS's graphs will be skewed to make their product look better, but the power figures will vary from car to car obviously depending on the other mods to support these turbos.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
