hey guys, im after some feed back on the garrett T04b turbo, all i know it that it has a .60 A/R Front and 1.00 A/R Rear, and runs a bush sytle bearing set up. ive got the high mount manifold for it and external gate. i just dont wanna buy crap. any info would be helpful, thanks heaps guys
https://www.sau.com.au/forums/topic/245306-garrett-t04b-trubo/
My advice, take your money out, all of it, fan it out in your hand, hold it with the fan facing down..............now get a cigarette lighter and set it all alight...........
If you want to waste $$$$ at least this way you will get something out of it!!!
The T04 is way too big, the 1.00 rear is light switch stuff at 7,000 rpm if at all, aim lower, a 60/70 something or around.
save your money and get something decent... Think what you want it for, and what power you want to achieve, look through the Dyno thread under forced injection and see there mods and what Turbo they are running.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
