As many of you may be aware the Haltech R35 GTR Skyline had a catastrophic blow up on Friday the 24th if October. Our GTR has been running on a new platform of Haltech engine management flawlessly for over 5000km's now.
The car was being track tested at Eastern Creek raceway
(http://www.eastern-creek-raceway.com/) when the engine let go. The car had completed countless flat out laps with the engine producing 400kw at the wheels, up from 300kw at the wheels - The driver tells me it was a terrific ride!
After finishing Haltech's latest Flat shifting calibrations a few more test laps had to be carried out. With no sign of trouble the car went out and successfully completed 2 more laps before finishing up on the side of the track leaving a trail of oil and plume of smoke behind it.
It was time to put it in the trailer and go back to the workshop to pull it down. After building up enough courage our in-house mechanic removed the VR38DETT from the car and set it up on the engine stand.
A few hours later the engine was fully stripped and the damage to the engine was clear - It appears Haltech have found the limits of Nissans new super car!
The engine had met its maker.
Piston #1 and #3 had separated from their lower halves right through the center of the gudgeon pin. As the Conrod's had no piston's to guide them up and down the bore they started smashing the bore, block, oil pump, sump and anything else that got in their way.
Due to the massive damage to the block we will need to replace it. And figure it's a great time to make the engine a little stronger. We will be boring the motor out and installing Darton sleeves, replacing the factory cast pistons with a study Forged unit as well as installing a set of Billet conrods. This should allow the engine to reliably produce over 400Kw at the wheels and handle the pressure.
Keep an eye on the Haltech website or drop us an email anytime for further updates.
this is how the R&D works.
Drive it and upgrade it slowly until it let's go.
Once it lets go, research the causes and weaknesses, and built a package that will ultimately make the identified sections stronger, and allow much more power and upgrades to occur.
Once you have this package in, tested and showing potential you start selling the package, and perform the original process all over again.
As you get more and more performance mods, you add to stage 1's package until the engine blows up again.
Now you have the upper limit of stage 1, and the supporting aftermarket mods for it.
Once you rebuild the second motor, you have the base line for stage 2 under way, and you keep upgrading until you blow the motor again, and you again have the stage 2 kit, the supporting mods, and the upper limit all sussed out.
B.
drop us all a line when you get a price on the block and other parts from nissan :D
will be interesting in the coming months whats going to happen to alot of the other cars that are pushing numbers.
good luck with it anyway and also glad to see Aussies leading the way with this kind of stuff!
...and also glad to see Aussies leading the way with this kind of stuff!
Blowing cars up? :D
Just kidding. 400AWkW is quite astounding if the only thing changed was the ECU. So does that mean the car could have reliable and comfortably ran 350AWkW by changing just teh ecu without many dramas?
I have been waiting for this also. Will be interesting to see if other failures result from the same thing.
Also interested to see how much all new gear will cost to strengthen it for the next round of abuse
Hmm should chuck a 2J in there, 400rwkw on stock internals wouldn't be a problem then :P
j/k
like someone said, good time for some R&D and gives them a chance for a good footing in the modification of R35s.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
