As many of you may be aware the Haltech R35 GTR Skyline had a catastrophic blow up on Friday the 24th if October. Our GTR has been running on a new platform of Haltech engine management flawlessly for over 5000km's now.
The car was being track tested at Eastern Creek raceway
(http://www.eastern-creek-raceway.com/) when the engine let go. The car had completed countless flat out laps with the engine producing 400kw at the wheels, up from 300kw at the wheels - The driver tells me it was a terrific ride!
After finishing Haltech's latest Flat shifting calibrations a few more test laps had to be carried out. With no sign of trouble the car went out and successfully completed 2 more laps before finishing up on the side of the track leaving a trail of oil and plume of smoke behind it.
It was time to put it in the trailer and go back to the workshop to pull it down. After building up enough courage our in-house mechanic removed the VR38DETT from the car and set it up on the engine stand.
A few hours later the engine was fully stripped and the damage to the engine was clear - It appears Haltech have found the limits of Nissans new super car!
The engine had met its maker.
Piston #1 and #3 had separated from their lower halves right through the center of the gudgeon pin. As the Conrod's had no piston's to guide them up and down the bore they started smashing the bore, block, oil pump, sump and anything else that got in their way.
Due to the massive damage to the block we will need to replace it. And figure it's a great time to make the engine a little stronger. We will be boring the motor out and installing Darton sleeves, replacing the factory cast pistons with a study Forged unit as well as installing a set of Billet conrods. This should allow the engine to reliably produce over 400Kw at the wheels and handle the pressure.
Keep an eye on the Haltech website or drop us an email anytime for further updates.
this is how the R&D works.
Drive it and upgrade it slowly until it let's go.
Once it lets go, research the causes and weaknesses, and built a package that will ultimately make the identified sections stronger, and allow much more power and upgrades to occur.
Once you have this package in, tested and showing potential you start selling the package, and perform the original process all over again.
As you get more and more performance mods, you add to stage 1's package until the engine blows up again.
Now you have the upper limit of stage 1, and the supporting aftermarket mods for it.
Once you rebuild the second motor, you have the base line for stage 2 under way, and you keep upgrading until you blow the motor again, and you again have the stage 2 kit, the supporting mods, and the upper limit all sussed out.
B.
drop us all a line when you get a price on the block and other parts from nissan :D
will be interesting in the coming months whats going to happen to alot of the other cars that are pushing numbers.
good luck with it anyway and also glad to see Aussies leading the way with this kind of stuff!
...and also glad to see Aussies leading the way with this kind of stuff!
Blowing cars up? :D
Just kidding. 400AWkW is quite astounding if the only thing changed was the ECU. So does that mean the car could have reliable and comfortably ran 350AWkW by changing just teh ecu without many dramas?
I have been waiting for this also. Will be interesting to see if other failures result from the same thing.
Also interested to see how much all new gear will cost to strengthen it for the next round of abuse
Hmm should chuck a 2J in there, 400rwkw on stock internals wouldn't be a problem then :P
j/k
like someone said, good time for some R&D and gives them a chance for a good footing in the modification of R35s.
    • I know this is a super old topic, but what ended up being the problem?
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
