It appears that Haltech is pretty lucky to get a replacement engine:
Nissan will continue its history of refusing to offer crate engines and gearboxes to all but a few select Nissan dealerships.
Nissan has explained that the parts withheld are “highly engineered, using technologies unique to Nissan”. So, it reasons, who receives them should be closely controlled to protect Nissan’s intellectual property.
Source
  • Replies 99
give me a break. as if you couldn't buy an r35 half cut if you wanted to. hell someone in oz already has one.
I really don't get all the fuss in this thread. These guys pushed the engine and have a rebuild coming. I did 4 motors last year and don't push them half as hard as these guys have. Good luck to them for putting their money out to develop their product like this.
I understand pretty every race r35 is Oz is running a haltec, so all of the jealous kids might as well pipe down. I don't see anyone chucking a rebadged link into them. All the best with the development, I hope you have more good results to share
Source
Yeah, this is what some people in the US are finding out at the moment-
Personally if I buy a car its on the basis that the manufacturer will just sell me the parts to fix it myself if needed... I mean for f*cks sake just looking at most of those parts listed theres only a couple I'd think twice about DIY (like the engine) because the rest is pretty much plug and play.
What a crock of shit
Two things-
1. The 'engine' restriction doesn't seem to mention cylinder heads. hmmm...
2. Why the hell is Nissan U.S HQ in Nashville? "Gosh darn Dolly, this 'ere Nee-san dun feel nuthing like ma ol' F-150 pickup..."
sounds like your taking a shot at dirtgarage/ray hall? have they been hanging shit on haltec or something?
forgive me for not keeping up with all the drama, and no, i havent read very much of this thread.
Nissan was much cooler when they were losing money hand-over-fist, it has to be said :)
I blame their being shacked-up with the snooty French.
Yeah Nissan's 90s jdm car range was quite incredible!
But nissan would be no more without carlos/renault and without adapting to recent market changes.
I dont like that they arent making the range of 'sports' cars they were, but atleast they have put all their marbles in with the R35.. And it payed off :P
That document looks like a nightmare for the privateer
  • 5 months later...
  • 3 weeks later...
  • 3 weeks later...
A couple of questions if anyone knows the answers, it would be most appreciated.
1. How much kw at the wheels was this car running over stock when it blew up?
2. How much would it cost to rebuild the car after suc a failure?
thanks
1. Approximately 400kW @ wheels I believe.
2. Including labour probably about the same money as a used stock R34 GT-R
It depends on if you can score access to the parts or not. Yes if you must buy a whole Engine Assy it is expensive. Nissan are becoming more open to selling bare blocks however and the price is much more reasonable if you buy one and put aftermarket pistons and rods in.
All depends on what was damaged in the engine failure but yes it can add up very quickly...
500+ hp with mid-pipe and new Map is plenty.. :P ...no need to squeeze an already highly tuned motor
for more....... :D
Seems like that grass is still greener on the other side of that fence.....
It's funny how once you get to the other side and take a glance back at your old grass, sometimes it looks better than the stuff you just hopped to :D
Newfound appreciation for old grass!
As a statistics nut I have to side with the people who say it's just one (possible two or three) engine out of however many there are. This said, engines are produced with as much control over variance as possible (despite minute differences between even two of the exact same engine) - so it is still a good representation of an approximate limitation for the engine. And THAT said, given the complexity of engines, without knowing exactly what caused this it's very hard to say whether it is a factory or tuner fault. Time will tell I guess.
  • 2 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
