Got my defect virginity busted last night on the way to dinner...wasn't driving like a tool, wasn't speeding, not even a breath test and he even said "After 25 years on the highway, you can spot a car thats too low". Got done for eyebrow height, 325/305 when it should be 345/355...the rears are 5cm! I didn't even remember my rears looking so high!
Only annoyed that all the little things that I've been putting off needs to be done right now.
Anyone got a checklist for things to do? I can just plug my stock ECU back in running R34 N1's right?
https://www.sau.com.au/forums/topic/245360-it-had-to-happen-sooner-or-later/
  • Replies 83
cant remember what the figure is but i can dig it up, but i remember distintively the min eye height being the same front n rear.
after 25 years of being on highway patrol me thinks he is bored n angry he is not praised like the cops on tv he watched as a kid.
Cops are really putting down extra heat now, due to the recent events of accidents, P plate issues relating with imports, etc etc.
Pretty sure you'll have to put stock turbo's back on with the stock ECU, unless you have them engineered. Or do R34 N1's look exactly the same as regular twins?!
Am I the only person here who has been defected for 3 things and not sent to regency?...
When I had my R32 I got done for monster tacho and shift light, steering wheel and turbo timer and just got sent to the cop shop for a check when I had fixed those things....
Probably cause you're female and the cop liked what he saw? *shrug*
-D
Yeah gotta cop ride height on the chin, there's no way I can say it doesn't "look" that low when hes gotten the tape measure out already...
I found the PDF that contains the eyebrow heights...it doesn't have my car on there! 89 GTR, they've got:
GT'R June 91 onwards 375/355 (WTF? 375?)
R32 Turbo Low Volume Import 91 onwards 360/360 (pretty sure this is GTSt)
Only one that matches the year would be June 88 TI/Silhouette GTS 330/325 :D
For those playing at home: Eyebrow heights
Will be interested to see how you get on with the turbs. Was recently told that Regency had wised up to the swapping of similar looking turbos and that nothing but stock will get you through. Don't know how they can tell and it could all be a pile of steaming dog shyte so let us know how you get on.
Guest
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
