Got my defect virginity busted last night on the way to dinner...wasn't driving like a tool, wasn't speeding, not even a breath test and he even said "After 25 years on the highway, you can spot a car thats too low". Got done for eyebrow height, 325/305 when it should be 345/355...the rears are 5cm! I didn't even remember my rears looking so high!
Only annoyed that all the little things that I've been putting off needs to be done right now.
Anyone got a checklist for things to do? I can just plug my stock ECU back in running R34 N1's right?
https://www.sau.com.au/forums/topic/245360-it-had-to-happen-sooner-or-later/
  • Replies 83
cant remember what the figure is but i can dig it up, but i remember distintively the min eye height being the same front n rear.
after 25 years of being on highway patrol me thinks he is bored n angry he is not praised like the cops on tv he watched as a kid.
Cops are really putting down extra heat now, due to the recent events of accidents, P plate issues relating with imports, etc etc.
Pretty sure you'll have to put stock turbo's back on with the stock ECU, unless you have them engineered. Or do R34 N1's look exactly the same as regular twins?!
Am I the only person here who has been defected for 3 things and not sent to regency?...
When I had my R32 I got done for monster tacho and shift light, steering wheel and turbo timer and just got sent to the cop shop for a check when I had fixed those things....
Probably cause you're female and the cop liked what he saw? *shrug*
-D
Yeah gotta cop ride height on the chin, there's no way I can say it doesn't "look" that low when hes gotten the tape measure out already...
I found the PDF that contains the eyebrow heights...it doesn't have my car on there! 89 GTR, they've got:
GT'R June 91 onwards 375/355 (WTF? 375?)
R32 Turbo Low Volume Import 91 onwards 360/360 (pretty sure this is GTSt)
Only one that matches the year would be June 88 TI/Silhouette GTS 330/325 :D
For those playing at home: Eyebrow heights
Will be interested to see how you get on with the turbs. Was recently told that Regency had wised up to the swapping of similar looking turbos and that nothing but stock will get you through. Don't know how they can tell and it could all be a pile of steaming dog shyte so let us know how you get on.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
