  • Replies 83
hey questions, can they send you all the way to regency of they defect you way out in country SA somewhere? would seem a bit stupid having to travel all the way to adelaide just to clear a defect? they would just send you to the closest cop shop in this situation?
Yeah gotta cop ride height on the chin, there's no way I can say it doesn't "look" that low when hes gotten the tape measure out already...
I found the PDF that contains the eyebrow heights...it doesn't have my car on there! 89 GTR, they've got:
GT'R June 91 onwards 375/355 (WTF? 375?)
R32 Turbo Low Volume Import 91 onwards 360/360 (pretty sure this is GTSt)
Only one that matches the year would be June 88 TI/Silhouette GTS 330/325 :banana:
For those playing at home: Eyebrow heights
That PDF is way out of date.
Speak to Vehicle standards they too will tell you it has changed.
For example the R32 GTST used to be 360mm all round.
Now its 345mm front 355mm rear.
When lowering a vehicle body, either front or rear, the limiting factor is the clearance between the rubber bump
stop and the corresponding metal stop. This dimension must not be reduced by more than one third of that
specified by the manufacturer.
Transport SA has a list of acceptable suspension and eyebrow heights (the measurement from the centre of the
wheel vertically upward to the edge of the mudguard) for most passenger vehicles and can be contacted to
verify if the ride height of a vehicle is within acceptable limits.
Info_bulletin_3.pdf
Only one that matches the year would be June 88 TI/Silhouette GTS 330/325 :D
haha that is soooo wrong
i just got cleared from regency not long ago
R32 GTS-t is 345 and 355
GTR is very very very close to this as i remember seeing it in the cops book but clarify with regency, BUT GO TO VEHICLE STANDARDS and check, dont ring............
Guest CleanAndSimple
Found This On Another Website. May Be Helpful As Helped Me, (Even Tho I Have To Go Back SIGH)
Just make sure u have the proper sealed battery (if its in the boot) and all ur splash guards are alright. Sigh Seems Stupid But Thats All They Cud Get From My Car LOL!.
Best Of Luck
In Cabin:
1. check every single bulb on your car is functional, including hazards
2. washer jets work and u have water in the reservoir
3. all of your seats are legal. Seatbelts ALL work. Seat slides forwards and backwards as it is meant to.
4. get subs and amps out. The less non standard stuff they notice, the better. Go in with your car stock as possible.
5. your steering wheel is stock or legal. This applies also to the boss. It cancels the indicators.
6. horn works
7. windows are all working and there’s no crack.
8. all panels etc are fixed and secure.
9. tint is legal. Make sure it’s legal. A lot of guys are failing on this. if it’s not, take it off. If you’re not sure, find out. Be sure.
10. No loose wires anywhere hanging around the place.
Sub Frame & Shell:
1. all boots on everything are in good nick. CV boots, steering boots, strut boots. Mikey didn’t get thru cos of this kind of thing.
2. no significant cracks to subframe or suspension assemblies.
3. all panels are fixed and secure. This includes little things like your wheel arch liners, grill, etc. Make sure all your panel pins are in place and doing their job.
4. your aftermarket exhaust isn’t touching anything it shouldn’t, including your *handbrake cable and assembly*
5. no oil leaks, GB leaks, radiator leaks etc etc etc
Wheels & Suspension:
1. your wheel alignment is reasonable (ie wheels aren’t touching, or nearly touching, any suspension componentry)
2. wheels are legal. If you’re not sure, check. A general rule of thumb is that u can go 2” rim diameter greater and 25mm wider, but check with regency before you go thru. Rules are different for each model, and for different manufacturing years.
3. tyres in good nick, including your spare tyre.
4. brakes are good. Callipers are legal.
5. your ride height is as close to stock as possible.
Engine & Drivetrain:
1. you’re not blowing smoke
2. your aftermarket pod is secured. Afm is plugged in, O2 sensor is plugged in. inputs (sensors etc) are plugged.
3. your egr is plumbed in and functional.
4. no structural rust
5. you have documentation to demonstrate that anything non standard meets the relevant Australian Design Rules (ADRs) and Australian Standards (eg steering wheel)
6. If you have a visible aftermarket ecu be prepared for an emissions test. It isn’t wise to go thru with anything non standard, especially if it’s visible.
Your Attitude.
1. Be cool, friendly, and relaxed.
2. Demonstrate that you respect their rules and knowledge.
3. Remember your manners
4. If they pull you up on anything, politely ask what is needed to make it legal.
5. Bite your tongue. They don't like attitude.
so even if coil overs are set at or above standard required height its an issue?? from that impressive list you have that is my only downfall :D
yup. any form of adjustable suspension is an issue.
I've got a clunk going on in the front right suspension, probably a worn bush but I'll get it looked at. Seems from that list only thing that would get me is ECU and ride height.
Spare tire...what about the wheelbarrow tire? IE: Space saver?
I also heard that tears in the seat fabric are bad, I've got the standard R32 GTR hole in the drivers side seat...
Well when I was defected in Adelaide and not sent to regency, the car was registered in Port Lincoln.....
Space saver is fine, as it came stock with the vehicle. Just make sure it is secured.
Will be interested to see how you get on with the turbs. Was recently told that Regency had wised up to the swapping of similar looking turbos and that nothing but stock will get you through. Don't know how they can tell and it could all be a pile of steaming dog shyte so let us know how you get on.
Bigger turbo/changed turbo will be a huge defect due to it changing emissions. I cannot see that a R32 GTR stock turbo will look the same as a R34 N1 turbo. Plus the model numbers will be different.
The only turbo modification you'll get away with is if you've steel wheeled a ceramic wheeled R32 GTR Stock turbo, and possibly high-flowed it, as they'll only check the model number, etc on the turbo.
I had a mate who has a R32 GTS-t who went through Regency with a bigger HKS turbo. He got done for it, and got sent to get a full emissions test.
They wouldn't care about the appearance of the seat (rips in it - unless they're incredibly deep like someone has gone on a seat stabbing rampage) providing that:
1. The seat is secured, bolted down, and the back rest doesn't have any play in it (I got done for this back in my Familia, my back rest in the drivers seat had the slightest play in it, and I got pinged for it)
2. The seat belt can't have any frays in it on the fabric
3. The seat belt has to retract by itself and not just hang there once you've pulled it out
4. The seat must be standard (but by the sounds of it, yours is)
Yes, if you're registered address of the car is a certain amount of kilometres away from Regency, they will send you to the nearest police station/checking station. So in your case, you'd get sent to the local cop shop regardless of the defect.
Edit: Check all your bushes!! This is a huge thing they like to check! If any of them are worn, replace them before you go through!!
Edited by CRoNic...
Here's the current version.. i called up Vehicles Standards and asked the gentleman to send it over.
IB44__August_2008_long_Version.pdf August 2008
i got stung when i had my 31 go thru a few years back. the seat was slightly worn, and they reckoned they could "feel" the hinge in the seat. So best to go thru with no tears/excessive wear if possible
for just one defect are they really going to go over your car with a fine tooth comb??
Absolutely, no doubt about it, happened to me about 5 months ago. They will crawl in, on, over and under the car. They'll use a torch to look into the dark recesses and may even ask you to drop your pants and bend over, they are very thorough.
You can go into Regency for a blown light bulb and come out with a $3,000 list of repairs.
Have been told that they are now checking turbo serial numbers but don't know if this is true or not.
So if my seat is worn down from getting in and out (as in, the bucket side of it) so its gone a bit flat, and if they press on and it and can feel the hinge (I take it any metal in this area) then thats a defect?
I also heard a week or 2 ago that over the next 6 weeks the cops are having a crack down on all Jap imports. Heard from a cop who pulled this person over. I would show the txt message but lost it.
