s13s15 Posted September 10, 2003 Share Posted September 10, 2003 wat's the best turbo for the rb20det, without too much lag, fuel cut etc. and with plenty of performance??????? :burnout: n e ideas or info wuld b much appreciated Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/ Share on other sites More sharing options...
Ronin Posted September 10, 2003 Share Posted September 10, 2003 t88 na hks 2530 are supposed to work quite well, if you have the bling bling. If not a cheaper option would be an rb25 turbo, i have one on my 32 and it goes quite well. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523086 Share on other sites More sharing options...
s13s15 Posted September 10, 2003 Author Share Posted September 10, 2003 lol t88, k tx man...n e 1 disagree or has a better idea Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523094 Share on other sites More sharing options...
DCIEVE Posted September 10, 2003 Share Posted September 10, 2003 just high flow it. not much more lag than std, and mines pushing 250rwhp at 1bar. thats got the afm maxed, the injectors are prob on the edge too being a red top. strangely the std fuel pump still has some left, unless it was modified in jp. can be done for around 1k or another option is the rb25 unit with similar results but ceramic exh so itll be on the limit Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523127 Share on other sites More sharing options...
Roy Posted September 10, 2003 Share Posted September 10, 2003 A HKS2530 will give you "Plenty of performance" - around 210-230rwks Beyond that it cost substantial $$$. What $$$ are you realistically looking at spending on just turbo??? I would love to see what a properly setup HKS2835 with manifold/wastegate/ECU/injectors/AFM would do on an RB20. A Trust TD06L2-20G-8cm kit with manifold/wastegate is about as big as id go, any bigger and boost response may be compromised a little too much. (Lag in negligible, with boost response bumped up about 1200-1500rpm) Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523156 Share on other sites More sharing options...
rbs13 Posted September 10, 2003 Share Posted September 10, 2003 2530 is the go from what iv gathered.. not really worth going 2540 just adds lag and is only good for top end.. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523404 Share on other sites More sharing options...
Sydneykid Posted September 10, 2003 Share Posted September 10, 2003 Hi flowed RB25DET turbo, works great on our RB20DET. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523512 Share on other sites More sharing options...
Steve Posted September 10, 2003 Share Posted September 10, 2003 HKS2530 - killer. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523534 Share on other sites More sharing options...
bbenny Posted September 10, 2003 Share Posted September 10, 2003 HKS2530 is defenantly the go gives more bang for your buck - pull over 280rwhp on less than 1bar, just get your ecu tuned or a boost cut defender to run more boost. speaking from experience but they are very responsive. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-523661 Share on other sites More sharing options...
say1anonly Posted December 14, 2012 Share Posted December 14, 2012 but i can't find HKS 2530...only HKS 2510 and 2535. is 30 and 35 are same in this case? Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668329 Share on other sites More sharing options...
AngryRB Posted December 14, 2012 Share Posted December 14, 2012 wat's the best turbo for the rb20det, without too much lag, fuel cut etc. and with plenty of performance??????? :burnout: n e ideas or info wuld b much appreciated a garrett 2871r would be in the range, a 0.63 rear housing and cranked up to 18-20psi with possibly some E85 to make it come alive even more.. there common on sr20's from what ive seen/read. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668345 Share on other sites More sharing options...
robbo_rb180 Posted December 14, 2012 Share Posted December 14, 2012 2871r or a kando tdo5 8cm. tomei arms turbos have been getting good results have a look here for turbo comparison thread http://www.nissansilvia.com/forums/index.php?showforum=2 Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668347 Share on other sites More sharing options...
bradsm87 Posted December 14, 2012 Share Posted December 14, 2012 You mentioned fuel cut. There's no point upgrading the ECU if you're not going to remap or Nistune the ECU at least. I'd go a Garrett GTX3067R with an ATP divided .82 housing on stock manifold modded for external gate. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668357 Share on other sites More sharing options...
raZ1911 Posted December 14, 2012 Share Posted December 14, 2012 How much power are you aiming for? They have nothing before 4 grand anyway just get a TD06L2 20G 8cm (like $799 from the kando or a billet one from hypergear), a few people have said they have moved from something like a 2530 to something larger and not noticed much difference. But it depends what you want if you want a whole highmount setup or if you want to keep it as stock looking as possible etc etc. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668369 Share on other sites More sharing options...
Jap_star Posted December 14, 2012 Share Posted December 14, 2012 You mentioned fuel cut. There's no point upgrading the ECU if you're not going to remap or Nistune the ECU at least. I'd go a Garrett GTX3067R with an ATP divided .82 housing on stock manifold modded for external gate. That would be quite disgusting to drive until 6000. Divided housing then put it on a stock manifold, not really that helpful there Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668406 Share on other sites More sharing options...
sneakey pete Posted December 14, 2012 Share Posted December 14, 2012 Post dates... check em... Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668473 Share on other sites More sharing options...
Serpandrew Posted December 14, 2012 Share Posted December 14, 2012 holy sh*t 2003 haha Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668538 Share on other sites More sharing options...
hypergear Posted December 14, 2012 Share Posted December 14, 2012 Thats when I bought my first R33, Auto 93 model that costed me $17500 back then. Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668543 Share on other sites More sharing options...
bradsm87 Posted December 14, 2012 Share Posted December 14, 2012 (edited) Divided housing then put it on a stock manifold, not really that helpful there I'm assuming RB20 manifolds are the same as RB25 ones and are divided (other than the 5mm gap which can be welded up)? Why would it be disgusting until 6000? Stock manifold will have better response than aftermarket. I am referring to the new smaller GTX3067R, not a typo of a GTX3076R. The divided .82 housing has better response than an open .63. This setup would be more responsive than a GT-RS/GT2871R with the right tuning and cam gears with a fair bit more top-end potential. Why would this be discusting until 6000? Disgusting on tyres I guess haha. Edited December 14, 2012 by bradsm87 Link to comment https://www.sau.com.au/forums/topic/24537-best-turbo-for-rb20det/#findComment-6668627 Share on other sites More sharing options...
