Heaps N Heaps Of Parts Nismo 2 Way, Safety21 Full Cage, Tein Coilovers, Hks 2535, Recaro Pair, Whiteline Sway Bars, Arc, Apexi, Greddy, Momo Ect Ect
Prices are FIRM, seriously don't waste both our times with stupid offers.
and please dont pm me asking for stuff that ISNT listed like power steering pumps ect
Note: all parts are spares off my r32 with rb25
HKS 2535 - $1300- purchased brand new when i bought the car, less then 2 years old, less then 10,000kms.. perfect condition.
3"dump/front - $250
metal intake pipe $150
APEXi N1 Evolution Exhaust - $700
ARC Airbox - $ 200
Oil catch can + mounting kit + hoses - $50
Brand new Hypergear 600x300x75mm cooler - $150
Brand new M-Spec 50mm Duel Core Radiator - $250
Brand new rb25 water pump $150
Reconditioned starter motor $100
Central 20 Ecu - re mappable apparently - $150
Greddy E-Manage Blue $400
emanage Injector harness - $50
Nismo 2way for s14/r33 housing but will fit any r32 as i have new superpro bushes that u need for 32s. $800
Safety 21 7 point full roll cage, padded where it matters - comes with custom door trims cut nearly (can also swap with ur carpet so u dont need 2 cut urs) - $800
Front Juran strut brace - $80
Rear Cusco strut brace - $80
Tien HR coilovers - Superlow - $600, no leaks no nothing
Tien Front Upper Control arm (-3.2deg camber) $300
R32 GTST Brand new Whiteline/Selby Adjustable Front Sway Bar $200 - brand new not installed - comes with bar links and bushes
R32 GT4/GTR Whiteline/Selby Adjustable Rear Sway Bar$200 - comes with bar links and bushes
Volk 17x8" +30 $400 a pair
s15 stockies $150 pair
GTR Bonnet - slight damage, easy fix, $300
Modified 1993 Type M Front bar - Opened mouth + added garden edging lip - $200
Type M sideskirts - $200
Recaro Seats with recaro rails- Pair- has a small tear on both seats where the seat belt rubs, can be sewed up or maybe just put a patch of leather or something on it so it wont tear again $800
OMP style Deep Dish Steering wheel $100
momo steering wheel $150
Autometer - 30psi boost gauge $100
Autometer - Water temp gauge (needs new sensor) $80
Alpine CDA-9827 - $200
Aftermarket rear speakers $50
for photos just look through this thead:
http://www.nissansilvia.com/forums/index.p...howtopic=329840
if u need something specific let me know.
Edited by DjeMz
  • Replies 63
interested in Rear Cusco strut brace and front/rear Adjustable Sway Bar if they both suitable to for 32GTR?
which suburb in melb??
Edited by BWRGTR
rear strut bar will fit, rear sway bar will fit (as i have a gtr cradle) not 100% sure on the front though...
hey man do you have the elbow that goes from the turbo to the intercooler.it comes off the compressor side of the turbo.
intrested in the radiator and arc airbox as a pair more the radiator post pics up of it?? im located in melb so i can pick it up
any idea if the dump/front pipe would fit an rb25 - r34?
and is the cooler complete with pipng or just core?
cheers
pics on these thanks. is the cooler kit complete or just a core as abovementioned?
R-Spec, R32 front pipe wont fit a R34 unfortunately. dump will tho.
djemz, pm sent regarding injector harness :banana:
Hey mate, can i get pics of the following if they are all still available?
Metal intake pipe $150
Cheers
ill take the turbo
cya tom mate!
i do, i had it custom made my protek, its a smooth bend instead of the rough stock one.. im still unsure if im going SMIC or keeping mysetup as i already cut a hole n stuff for it..
This is the only pic i got at the moment sorry, i will take some more if u want?
cheers
yeah as mentioned i dont think it will fit sorry
cooler n piping arnt for sale just yet
Pm sent.
replied mate
hey mate
please look up at the above pic, again only recent pic of engine bay i have... if u need more let me know.
Cheers
hey mate, hows things?
everything available except rear strut bar
the arc box 2 suit rb25 or 26?
to suit r32, it could fit r33, probably just cable tie it down nice n tight so it duznt rattle
Rear strut bar sold
FMIC + piping not for sale anymore
oil catch can sold
Edited by DjeMz
zututututuu pipe
radiator (excuse the dirt :))
arc airbox (blue stuff is the silicone i used instead of the gasket... took me ages to separate it from the afm)
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
