When i give 'er some revs in neutral the engine stutters for a second or two till the revs build up.
I have gone round tightening everything i can think of.
I have found a small (20mm) long open section where the zorst guy hasnt welded the resonator up properly. Also, when i rev i think i can hear a whistling sound from the AFM which is located just after the FMIC and prior to Greddy plenum.
Question is....which one or both?
Any ideas
Thanks
https://www.sau.com.au/forums/topic/245410-exhaust-or-afm/
Well exhaust you should weld up either way.
It does potentially sound AFM related, but the AFM 'should' play up all the time. Not just in neutral with a little free-rev...
It should misbehave off load/underload/intermittent for both etc until it gets worse and worse (thats how mine failed)
Could also be TPS perhaps not working correctly IMO... more likely TPS than AFM
https://www.sau.com.au/forums/topic/245410-exhaust-or-afm/#findComment-4269215
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
