Hi Guys,
Basically we are in a high technology industry and have access to a guy that seems to be able to make just about anything happen - both hardware and software. He is pretty much a genious in all reality.
I was just thinking out aloud and as we finish a certain development phase for our product (non car related), we will probably have some time to explore something which is of actual great interest to us, performance car engineering etc. So what I am going to do is start thinking of possible problems or issues that arise in the course of performance cars in general as well as specifically skylines mainly GTR's being a proud owner of one! Hopefully something will pop up that we may be able to find a solution for and actually solve a problem via inventing / creating some component/part/gadget/electronic device. For example something in the ECU side e.g. data logging or self learning just off the top off my head without studying what is out there.
So basically, I will be looking for:
1) Any ideas for an invention related to cars?
2) Any common problems or issues that are currently not solvable within reason?
3) A possible partner commercially in a car related project if it goes that far?
4) Or even any fun gizzmo or gadget that could be created to serve a purpose in car modification whether or not for commercial resale.
We also have access to a GTR engine specialist and a workshop facility for whatever its worth.
If anyone has any input, please let me know. I have learnt the SAU community is bunch of good people and thank the forums for an immense amount of very good information etc especially from the dedicated people who make it happen and provide their time & wisdom for the benefit of others. You know who you are. So thank you SAU for this!
I will over the coming weeks begin to research and generate ideas and see if there is anything that we can actually do! Should be interesting, I hope.
If anyone wants to contact me privately, my email address is a.wekara@optigolf.com.au, otherwise bring on any ideas openly whether crazy or not and we will see what is possible and what is not!
Thanks.
Regards,
Aku.
hmm.. thanks for the ideas... will note them and have a bit of a look!
For the anti-stall, I guess you would have to come up with an electronically controlled slave cylinder or something along those lines, a throttle controller, and integrate it with some external PCB board that talks with the ECU to make it happen via a button or something. Would definitely need a failsafe aspect too like mentioned.....Probably possible but is it viable in terms of low build cost or is it commercial enough to outlay a higher build cost and get returns from units, i'd say no from initial thoughts.......hmmm
On the turning circle, I dont know enough about the components to comment, but I guess it would work like an exaggerated HICAS physical undercarriage design permitting!
how about creating a new all computerised instrument cluster? although it's not really 'unknown territory' it would be something great.. like digital speedo and shit.. even one where you can set max k/s to be shown (320 k/s is too much i think for street use but 180 itnt enough for other uses).. so you could change if so desired...
ps make it for the GTT :D
Flush-sh-sh-sh!
How about a co-operative to resume research on the Sarich engine which even though it has more moving parts than the Wankel piston-less engine,...
i) is greener
ii) has a massive power to weight ratio
iii) is Australian designed
iv) can be still advised by the ultra-keen Ralph and Pat Sarich (even whilst Ralph is 69 yrs of age) in W.A.
F-L-A-P! To satisfy the ladies on SAU, the toilet seat just went down...
Flush-sh-sh-sh!
:D mans best work is created in the wc...right where it belongs.. nearly all of it is shi..... :glare:
:blink:
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
